Null Map on PCIII
Old May 20, 2009 | 09:50 PM
Taterdog's Avatar
Taterdog
Default Null Map on PCIII
I think I know the answer, but need a check. I have the HD stage 1 download installed plus a PCIII. If I run a null map (all zero's) on the PCIII, I should essentially be running the unmodified stage 1 download, correct? I'm leaning out my map, but assume as long as I stay positive in most places, I shouldn't be running any leaner than the HD download. What say you?
Old May 21, 2009 | 06:42 AM
harleytuner's Avatar
harleytuner
You are exactly correct. The PC MAP is set at zero for no change. Anypositive number in your A/F will richen up the block that you change.
Old May 21, 2009 | 06:49 AM
Taterdog's Avatar
Taterdog
Thanks, Harleytuner, I thought that was the case, but appreciate the confirmation. I've always been concerned about leaning out too much, but then got to thinking that I've got more leanout available without causing problems.
AZCFH
Mar 9, 2010 08:25 AM
Chief101
Jul 3, 2007 05:07 PM
badabing
May 29, 2007 04:54 PM
Arizona
Apr 15, 2007 11:42 AM
redhwk44
Sep 12, 2006 01:40 AM
