GPS or Speedometer:Which one do I believe?
Old May 22, 2009 | 06:48 AM
BigGdawg's Avatar
BigGdawg
My 2000 Springer had a certified speedo. Guess that might have been on. 3 mph off doesn't sound too bad. If they are consistently 3 mph off they must be very precision to stand calibration like that.
Old May 22, 2009 | 07:04 AM
grbrown's Avatar
grbrown
Its not just your bike speedo that is inaccurate, all vehicles vary and have done since the speedo was invented! There are variations in the accuracy of the speedo itself, also tyre wear to consider.
The speedo on many bikes is driven directly by a wheel. From fitting a new tyre to wearing it down to the wear marks is around a 2 percent difference. Later bikes tend to have gearbox driven speedos, but the same applies. So every vehicle with a speedo and mileometer has that sort of variation as an integral feature. 'Twas ever thus!
They cannot be as accurate as gps, which is using several satellites to monitor your every move....
Old May 22, 2009 | 07:17 AM
OldArmy's Avatar
OldArmy
Once you know that the speedos are off and by how much (mine is 3 over also) I go with the speedometer. Remember that the GPS reading is always a little behind and, if you are in terrain where the satellites are masked, very inaccurate for an up to the second reading. Steady state riding though, the GPS is more accurate.
Old May 22, 2009 | 07:23 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Mine is the same, 3 mph off. However in my car and the wife's car the GPS and Speedo are exactly the same.
Old May 22, 2009 | 07:34 AM
Trailfndr's Avatar
Trailfndr
I wish mine were only 3 mph off...on my 2006 Ultra, it was 4-5 miles off at 70 mph, on the 2008, its as much as 6 miles off at 70 mph. On the wifes deluxe, it seems to be close to right...(that or she can't read her speedo...she is always telling me that I am going too slowly, and should move up to speed limit while the GPS says I am slightly above speed limit...)
No matter...I trust the GPS to be accurate, and thats the reading that I use.
Old May 22, 2009 | 10:52 AM
iclick's Avatar
iclick
Originally Posted by OLD 96
I just bought a Garmin Nuvi 205 before I took a little run to New Mexico.The Garmin registers about 3 mph slower than speedo. Example,speedo says 75 mph-Garmin says 72mph. I thought I was gettin away with speeding until I put the Garmin on!
You can bet the GPS is right on the money, and the 3mph difference is about the normal error purposefully programmed on all late-model HD's. In the past FLH models had "certified" speedometers that were guaranteed to be within 2%, but no longer. My '96 RK's certified speedo was 1mph slow at 60mph. Almost all speedometers on cars and MC's are fast, some as much as 6%. I have speculated that this is a legal issue to insure that the vehicle is going no more than the indicated speed, even after modifications like larger tires, etc. My '07 SG is 4% fast (showing 62.5mph fast @ a true 60mph) when compared to the GPS as well as checked with mileage markers and a stopwatch.
Old May 22, 2009 | 11:27 AM
bagman1's Avatar
bagman1
I have the 550, and since I dropped the front gear because of the 103 build, my speedo is 4-6 mph off. 75 is about 68-70, and 110 was 104 on the speedo. The differences are not going to be the same across the entire speedo range at different speeds. Its not like the old cable drives. So you cant say if its 3 mph off its that way across the board. I trust the GPS
Old May 22, 2009 | 11:58 AM
Raaze07's Avatar
Raaze07
Absolutely go with the GPS, both of my last Harley's were reading on the optimistic side, whereas in the cars they match the GPS exactly.
Old May 22, 2009 | 12:29 PM
saw*me's Avatar
saw*me
The one that matters will be setting on the dash of that State Trooper's car over the next hill.
Tom
Old May 22, 2009 | 12:36 PM
Trojan63's Avatar
Trojan63
Originally Posted by Arizona
The GPS...
Most harleys read 3 mph faster than the true speed that the GPS will give you. Your bike is normal. My '09 and my '05 both were like this.
This subject has come up before and that's the overwhelming consensus when you hear from most members here it's 3 mph...
not just my harley, my mustang reads the same way.....both car and bike show 3mph faster than gps....
and my wifes car....subura...same way
