Draining Brake Fluid
Old May 22, 2009 | 01:28 PM
tencrore's Avatar
tencrore
Default Draining Brake Fluid
I am in the process of changing the front brake cables to the "diamondback" braided style and would like to know how to completely drain the front brakes of brake fluid.
I am thinking I would need some sort of tubing to go over the bleeders so that the brake fluid can drain into a container. If so, can anyone specify the type/size of tubing needed?
Thanks in advance for your help.
Old May 22, 2009 | 01:29 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Clear tubing. I don't know the size. Go to an auto parts store and ask them. They should know. It's cheap as can be.
Old May 22, 2009 | 01:38 PM
Taterdog's Avatar
Taterdog
Not sure what kind of brake fluid you're using, but don't get any on your paint.
Old May 22, 2009 | 01:39 PM
VTwin-Goodies
Former Sponsor
Good point. If it is dot 3 or 4 it will eat the paint away. Cover all; painted parts with thick blankets.
Old May 22, 2009 | 04:16 PM
dawg's Avatar
dawg
1/2" clear plastic tubing. Slide it over the bleeder valve, open bleeder and pump the fluid out. Put some cloths all around the master cylinder before taking the banjo off at the master. This will soak what little drips may come out of the master after you have pumped it out the bleeder.
Old May 22, 2009 | 04:54 PM
Black Flag's Avatar
Black Flag
and don't forget new brass crush washers for those banjo bolts. They are sacrificial parts; not meant to be re-used. An ounce of prevention, ya know...
Old May 22, 2009 | 04:57 PM
RHillbilly's Avatar
RHillbilly
I use a big turkey injecting syringe you just suck it right out no mess
Old May 22, 2009 | 05:07 PM
casique's Avatar
casique
I use SPEED BLEEDERS and they are awesome. They save a lot of time and frustration.
Old May 23, 2009 | 04:00 AM
emwolb's Avatar
emwolb
at lowes or home depot you can get the clear vinyl tubing priced per foot. cheap, and it's nice cause you can see the fluid as you're draining it. lots of available sizes, but i'd think closer to 3/16" i.d. measure your bleed nipples. then get just a tad smaller tubing so it'll slip on, but sorta tight so it doesn't leak. just my opinion. hope it helps.
Mohammed Alyahya
Apr 11, 2019 03:21 PM
Thunderhorse
May 28, 2014 11:55 AM
camshaks
Wheels/Tires
Feb 15, 2011 01:54 PM
Sash302
Sep 13, 2010 09:08 AM
softail 99
Jan 21, 2006 12:49 PM
