Motorcycle Lift
Old May 12, 2006 | 12:59 PM
a21m's Avatar
a21m
Default Motorcycle Lift
Those of you that use one, can you put the bike on the lift and then drain fluids or does that need to be done before lifting? the ones like sears or harbor freight etc sell.
Thanks
Andy
Old May 12, 2006 | 01:10 PM
PhilM's Avatar
PhilM
Default RE: Motorcycle Lift
My lift is a "Pit Bull".
WHile it is "possible" to drain the fluids on the lift, it's VERY unpractical ~ it makes a huge mess, as the rails are in the way and oil gets all over them. I drain fliuds on the ground.
Harbor and Northern both have some nice 5qt "short" drain pans that make it quite a bit easier to drain with the nike on the ground.
Old May 12, 2006 | 01:42 PM
Abnmarine's Avatar
Abnmarine
I have the Sears Craftsman Professional series lift. I can easily lift my bike and drain all of the fluids. I use a large plastic bowl to catch the fluids. It fits perfectly between the rollers of the lift. It's all about where you position the jack on the frame prior to raising it.
ORIGINAL: a21m
Thanks
Andy
Old May 12, 2006 | 04:09 PM
mlgoheen's Avatar
mlgoheen
I got one of these for my b-day along with the drain pan, havent tried it out yet but looks like it will work great.
http://www.jsjacks.com/
Old May 12, 2006 | 04:23 PM
Kahuna's Avatar
Kahuna
A good jack to use for changing fluids is the scissor jack! I've seen the Blackjack 1000 and some other similar jacks on Ebay for under $100. These jacks are awesome for lifting just the front or the rear for wheel cleaning. Or, just to lift the bike straight up for cleaning.
ORIGINAL: a21m
Thanks
Andy
Old May 12, 2006 | 08:11 PM
blueknight's Avatar
blueknight
I use Sears bike lift and it works well. I use one of mommas tupperware plastic boxes that hold a loaf of bread size. Box sits in arms of jack and very little to no mess if your careful and empty after draining oil from crankcase, before you do other drain.
Old May 12, 2006 | 10:25 PM
1flhtk4me's Avatar
1flhtk4me
I have a Craftsman lift but I dont need it to to change the oil.When the bike is on the Jiffy,the drain hole is tilted in the right dirrection for the oil to drain out.Now the tranny might be a diff. issue.
I find the lift handy for washing the bike,I can spin the wheels which makes it easier.
Old May 13, 2006 | 03:13 PM
dforeid's Avatar
dforeid
I've got the Craftsman, but I never lift the bike to drain any fluids. Just find it easier not too....
Old May 13, 2006 | 04:08 PM
lp's Avatar
lp
I lift mine up with a craftsman to change the tranny fluid. If I don't the fluid gets all over my softail shocks (fatboy). But for engine oil I leave it on the ground...
Old May 13, 2006 | 06:52 PM
WhoMe's Avatar
WhoMe
I have the harbor Freight lift. It works well. Although I use it all the time for cleaning, I find it easier to change the fluids with the bike on the ground.
