Fairing Oil Temperature Gauge
Old May 16, 2006 | 11:37 AM
jdag's Avatar
jdag
Default Fairing Oil Temperature Gauge
Do any of you know of an oil temperature gauge that can replace the (useless) air temp gauge in the fairing. I have a Street Glide, so would want the matching white faced gauge.
74439-00 is the only HD part I see, and it is black:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Thanks, John
Old May 16, 2006 | 11:39 AM
Rhinohd's Avatar
Rhinohd
Default RE: Fairing Oil Temperature Gauge
try this one... HD Oil Temp
Old May 16, 2006 | 12:09 PM
harley0711's Avatar
harley0711
I have one made by Roger Mcquen (not spelled right) - This guy was the first to do this, been in my bike now for almost two years and it works great. I am a fire fighter and at work this morning until 0800 - I will post here later with details... when I get home....
Old May 16, 2006 | 12:34 PM
jdag's Avatar
jdag
Thanks! I did a search on oil temp on HD's site and these did not come up.
Old May 16, 2006 | 12:52 PM
SubZer0's Avatar
SubZer0
Here ya go http://www.wallyscycleworld.com/virt...osdatapage.asp You want p/n [os] 21-GK61537C
Or you could just buy the one I have new in the box for $80.00. I'm not going to use it.
Old May 16, 2006 | 02:15 PM
vegashd's Avatar
vegashd
Funny how the one under Street glide on the Hd page is under "functional" versus the useless air temp gauge. Has anyone purchased this gauge? does it come with all ness. hardware? Seems to be going on the order sheet for the bike. This is awesome.
Old May 16, 2006 | 03:46 PM
Boatman's Avatar
Boatman
I just installed the silver oil face gauge in my SEEG but hasn't quit raining to try it out yet. It comes with the wiring and sending unit. It is nearly impossible to install the sender where the MOCO wants you to (in a supplied elbow fitting in the return hose from engine to oil tank). If you do install it there, the std chrome cover will not work any more. I installed the sending unit in the oil pan in the plug (removed) next to the engine oil drain plug. A lot easier and cleaner look-all you have to do is buy a bushing from Lowe's to adapt from the sender unit size to the pan plug size.
Old May 16, 2006 | 06:27 PM
Bryan TTM's Avatar
Bryan TTM
ORIGINAL: SubZer0
i'll buy it....check your pm's
Old May 16, 2006 | 09:30 PM
SxysCowboy's Avatar
SxysCowboy
there is one in JP cycles book that even says harley on it in the pic silver or black face
Old May 16, 2006 | 10:03 PM
Greb's Avatar
Greb
I was thinking of going with the compass, it at least is alot more usefull then that OAT gauge.
