slip ons vs true duals
Old Jun 10, 2009 | 06:02 PM
davewear's Avatar
davewear
i went thru a bunch of dyno sheets with my local tuner when i was originally in the market for true duals. the duals did not perform as well as the stock headpipes on '09 bikes in the lower end of the rev range and performed about the same in the upper end. i decided to stick with the stock head pipes.
the sheets i looked at were for bikes that had just pipes, high flow ac and pc or sert. tuner said the true duals started working better with higher comp motors and cams/head work.
Old Jun 10, 2009 | 06:05 PM
kingkingking's Avatar
kingkingking
Originally Posted by Hammer107
I recently asked the same question and a search of the forum turned up some conflicting information, mostly be people who like to speculate rather than actually know, if that makes sense.
I talked to a very reputable and well thought of forum vendor that has an excellent reputation. They recently dyno'd a 2009 SG stock headpipe as well as both dresser duals and V&H power duals on the same bike, same day, same dyno and same dyno operator.
No power gains from the aftermarket head pipes. They could have easily lied to gain a sale as I was ready to spend but instead they gained a customer for life. I LOVE dealing with vendors like that and will continue to do so for a long time, and I like spending money.
I had heard that the 09 headpipes were pretty good, and this confirmed it for me so I just ordered slipons and called it good.
This is great info. Every week we get a new thread asking "what headers should i run behind my 09 96"??? ". Now we know - stock. Any chance the reputable company could post the charts?
WingNut55's Avatar
WingNut55
I've Dynoed more than a few Dozen 09's with Stock Head pipes and there hard to beat.. Harley did alot of R&D on the 09 head pipes. Looks ( Heat if you dont tune it ) of the rear Cyl head pipe exiting or the right side is the only good reason to go True Duals ..
Old Jun 10, 2009 | 06:11 PM
kingkingking
Originally Posted by bobernet
The 09 headpipes are already a 2-1-2, so V&H power duals wouldn't be expected to do anything.
If the folks at Fullsac can be believed - based on their dyno testing, even the stock headpipes on CA bikes (with catalytic converter) do not restrict flow enough to alter performance on a stock TC bike.
The test described above apparently did not include a 2-1 system.
Not all 2-1-2s are created equal. The PDs have a smoother and neater collecter / splitter than the stock pipes, they will flow better.
Having said that you are probably right, PDs behind a 96 wouldnt make much difference.
Old Jun 10, 2009 | 06:43 PM
txfxstrider's Avatar
txfxstrider
Theoretically, you lose power and torque with true duals as compared to a 2 into 1 or the original with crossover. An exception being wide open throttle, big bore drag strip or racing situations. For normal Harley type riding you will probably notice very little difference in any of them, except for sound.
Old Jun 11, 2009 | 08:28 AM
steved57's Avatar
steved57
great information ! so thanks to everyone who replied !!
i am a reinhart fan so i am going to just install their slip-ons !!
steve
Old Jun 11, 2009 | 08:39 AM
GodFather's Avatar
GodFather
One thing to keep in mind is that if you buy the slip ons now and then decide to go true duals later, the slip ons might not fit the new exhaust pipe. If you think you might add the duals later double check they will still work. Might not be an issue for 09, but it is for 07.
Old Jun 11, 2009 | 11:18 AM
iclick's Avatar
iclick
Duals make HP and lose some TQ. 2-1 (or 2-1-2) make TQ and sacrifice HP.
2-1(-2) for getting started quickly, duals for top-end.
I thought TD's may increase HP slightly in modified bikes, but not stockers. In any case TQ in the low-end and midrange will suffer. For most riders of touring bikes this would not be a good trade-off even if there was a HP increase, slight as it might be.
Old Jun 11, 2009 | 11:31 AM
DoomBuggy's Avatar
DoomBuggy
I lost 2 ftlb of torque when I went True Duals on my '08. But, the cooler right leg more then made up for it. I did keep a fairly restrictive exhaust on my bike, SE touring mufflers, but the tech who tuned my bike did say that the TDs always come in a little behind stock pipes and a bunch behind 2-1-2 pipes. ( On the '08 )
iambill
Exhaust System Topics
Feb 6, 2015 02:51 PM
Gliden
Mar 18, 2010 11:00 AM
VicDawg
40
Sep 13, 2007 05:49 PM
Cannon00000
Jul 15, 2007 11:28 PM
fiddlinfool77
Mar 31, 2007 05:33 PM
