Vance & Hines baffles removal.
Old Jun 15, 2009 | 06:23 PM
Pierre's Avatar
Pierre
Cool Vance & Hines baffles removal.
I have a set of Vance & Hines slip on,i want to remove the baffle inside of them,someone know how to do this ? seem a very tight fit ...thanks
Old Jun 15, 2009 | 07:01 PM
Pierre's Avatar
Pierre
bump....
Old Jun 15, 2009 | 07:12 PM
1flhtk4me's Avatar
1flhtk4me
What model slipons?
Old Jun 15, 2009 | 07:35 PM
Pierre's Avatar
Pierre
Basic slip on
Old Jun 15, 2009 | 08:01 PM
kingkingking's Avatar
kingkingking
There are 2 screws underneath that hold the baffle in. Take the muffler off the bike, undo the screws, spray a bit of WD40 around and drive the baffle out with a wooden dowel.
Sounds easy but it isnt. Be careful clamping the muffler - I would make a bracket that bolts onto the support that you can use to clamp it in the vice.
Old Jun 15, 2009 | 08:52 PM
PacBlue_07's Avatar
PacBlue_07
Ok - I have the basic slip on as well, i dont know what year your bike is or if that even matters but you when i took my baffles out to remove the fiberglass batting around them i did not remove the slip on's from the pipes. I removed the two torx screws at the end of each slip on and used a cotter pin removal tool and pulled the baffles out, cut away the batting and put them right back in..... no touble
Old Jun 15, 2009 | 10:16 PM
1flhtk4me's Avatar
1flhtk4me
Do the basics rust like the oval baffles do?
Old Jun 16, 2009 | 04:54 AM
Pierre's Avatar
Pierre
Thanks guys for the tips
kevdog
Jun 25, 2017 10:19 PM
JeffJA
11
Nov 16, 2012 09:51 AM
ehale3
Jun 18, 2012 10:25 PM
1flhtk4me
Mar 15, 2008 10:07 AM
the*bear
Exhaust System Topics
Mar 1, 2008 11:03 AM
