Okay have a RKC with the King tour pak. I want to add the side marker lights and probably the spoiler light (not the tour pak lights). I wanted to know how/where to wire this thing. They make a harness for a street glide I believe but I also think there is an existing harness on these bikes and not on mine. I hate splicing into wires and would prefer a connector. Not sure if anyone makes one but I was wondering were to tap in. My guess would be where the lights to the rear connect to the main harness under the seat. I have the Kury panacea lighting so I am not sure if I can even hook up the two lights above without causing some sort of damage. Any thoughts?
The HD tour pak spoiler/LED is wired for connection to the accessory connector under your seat/in front of the battery. So, in its out-of-the-box condition, it's not set-up for quick disconnect. But you can easily making a quick disconnect with the same connectors and wire terminals used in the accessory connector and the harness that comes with the spoiler/LED. You could then splice the wires from the side marker lights to the spoiler/LED wiring harness inside the tour pak.
Frankly, even if you had the tour pak wiring harness on your bike that is found on Electra Glides, Road Glides, and Street Glides you would still have to either plug the spoiler/LED into the connector under the seat or splice those wires to the tour pak wiring.
