2009 Touring Oil Cooler
Old Jun 17, 2009 | 10:35 PM
the4thgearkid's Avatar
the4thgearkid
Default 2009 Touring Oil Cooler
If anyone has one installed, can you snap a pic and show the orientation of the mount where the oil filter goes on. It don't matter if the hose is connected or not.
Let me know if you installed it or if the dealer did it.
I am confused by looking all over the net.
If you could help me out I would appreciate it.
I am talking about how this part is mounted... This is not the exact part.
Old Jun 18, 2009 | 12:18 AM
digz`'s Avatar
digz`
I have one that the dealer installed , do you need a pic with filter off ?
Old Jun 18, 2009 | 03:50 AM
TN Houndog's Avatar
TN Houndog
A have a friend with a Screaming Eagle roadglide that has the factory mounted oil cooler. The two hose connections are in the 12 oclock position. BTW: the oil cooler adapter in your picture looks like one for an 08 or older bike. The oil filter adapter on the 09 SE has more space between the oil filter and the hose connections. I'm going to try to put the cooler off my 07 on my 09 and was looking closely at the differences last Sunday. I don't have access to his bike for pictures presently, and hope my description helps.
Old Jun 18, 2009 | 07:25 AM
07JakeelwoodHD's Avatar
07JakeelwoodHD
I installed my oil cooler yesterday the adapter needs to be in the 12 o clock position very easy install took about 30 min..
Old Jun 18, 2009 | 07:32 AM
FLHTCU Owner's Avatar
FLHTCU Owner
Ok, I have a silly-a$$ed question ....
Have no experience with oil coolers, but know the benefits. Does it require additional oil, or just utilize the 'normal' amount?
Old Jun 18, 2009 | 07:45 AM
raceframe's Avatar
raceframe
Default 08 cooler on 09
I too have looked at mounting a cooler from an 08 on a 09.So far the problems I have encountered have been due to the frame tubes being a larger diameter and when the 08 adaptor is mounted in its correct position I believe it will not clear the frame.I guess thats the reason for the 09 adaptors hose connections being moved up in the 12 oclock position. Also the hoses on the cooler have been moved to one on each side instead of both being on the left side. Keep us posted on what you find out.
Old Jun 18, 2009 | 04:21 PM
the4thgearkid
Nope, you can leave the filter on. I want to see the positions of the hoses. Seems like a resound 12 o'clock so far.
Old Jun 18, 2009 | 04:22 PM
the4thgearkid
Your right, that is for an 08' and older, for a softail. Thanks for the input.
Dannell53
Feb 17, 2012 07:19 AM
bmcgc
Jan 10, 2011 09:27 AM
Talldog
Oct 31, 2010 09:57 PM
Quadancer
Oil Archive (no new posts)
Mar 11, 2010 10:55 PM
whylee
Oct 14, 2008 07:41 PM
