Power Commander / Mapping Questions
Old Jun 20, 2009 | 07:05 PM
harley0711's Avatar
harley0711
Default Power Commander / Mapping Questions
OK people - I have a 2004 EG that I put Rhineharts true duals on back in Late 04 - at that time I also installed a Power commander III USB and had it dyno tuned. Fast forward to today - Needed a change in life - want to install the Vance & Hines 2/1 Pro Pipe HSs / Chrome... I have called Dyno Jet / Power Commander - they gave me two different 'Maps" to use
M807-028 Vance & Hines 2:1 Pro Pipe , Stage 1 ECM and Screamin Eagle air filter
M807-027 Vance & Hines 2:1 Pro Pipe, Stock ECM and Screamin Eagle air filter
Dyno also said a custom map could be made..
I called the local HD and another shop on the Dyno Jet web site
Both quoted $375 to do a custom map for both cyls and $275 to map each cyl the same WTF !!!!!!!!!!!!!!!!!!!!!!!!
So, for all you 'shade tree mech's' out there - how good are the 'maps' like above??? I can get my way through a computer somewhat, and I feel that I could most likley do a down load - anyone here done this????
Or has anyone put on the
Vance & Hines Pro HS 17533
http://www.vanceandhines.com/product...propipehs.html
Old Jun 20, 2009 | 07:08 PM
OG1's Avatar
OG1
the dyno tuned map will almost always be better than the canned map due to it running optimal AFR's for your specific bike. make sure you save the map you have now just in case no matter what you do.
Old Jun 20, 2009 | 07:18 PM
harley0711's Avatar
harley0711
Thanks - but at another $375 - I am NOT looking to run the 1/4 mile... just ride - all I have done to this bike is do the A/C = stage 1 - NO engine work
Old Jun 20, 2009 | 07:36 PM
OG1's Avatar
OG1
you will probably be fine with a canned map then. i would say use the map for a stock ecm, as the map for the stage 1 ecm download wont make quite as much change.
Old Jun 20, 2009 | 07:39 PM
RenoGlide's Avatar
RenoGlide
On your computer open both 27 & 28 and compare the tables. They could the same... seen it before. Load one in the PCIII & run it w/ fresh plugs & then do a plug check.
Or, ... You can back load the map thats in your PCIII from the bike to your computer then compare it to either 27 or 28 and see what the changes are. Often the changes are in certain throttle positions/ rpms say 20-60% throttle at 2500-4000 rpm. Make a custom map based on either whats in your bike or the map you chose & rename it then work off that. Could put you real close to where maybe only a dyno could tell the difference.
Old Jun 20, 2009 | 08:04 PM
harley0711's Avatar
harley0711
Sounds like you've done this before..... how about on your next ride through Turlock, I buy the beer??? lol.. Actually, I will be in Reno on July 11 starting our Ride to UT and up to Sturgis (Before the rally).... But the V&H will NOT be on yet...
Old Jun 20, 2009 | 10:23 PM
harley0711's Avatar
harley0711
RenoGlide - just reliazed who you are... I have been to your shop before, I am firefighter from Turlock, retired now.. I have bought several shields from you..
jhenry8208
May 15, 2013 03:39 AM
Chiledog
Mar 5, 2013 06:06 AM
Ring
Sep 30, 2009 08:04 AM
harley0711
Jun 27, 2009 01:04 AM
74_ironhead
May 22, 2008 07:12 PM
