change rear tire myself
Old Jun 22, 2009 | 01:45 PM
harley1958's Avatar
harley1958
If you have a lift it is easy. the hardest thing is to break the bead on the old tire . Most dealers will not touch changing the tire if you bought it elsewhere. I change mine --I figure if I do both I save at least $250.00 GO FOR IT
Old Jun 22, 2009 | 02:08 PM
mickael moore's Avatar
mickael moore
Ya'll ought to try those Dyna beads for balancing. Easy to put in use an engraver thingie to vibrate in the beads. www.dynabeads.com Been using them for years now. 2oz per wheel and last as long as the tire.
07 Ultra
SgtMaj of Marines (retired)
Once A Marine, Always A Marine
Old Jun 22, 2009 | 02:17 PM
Sharknose's Avatar
Sharknose
Originally Posted by xxxflhrci
I've been riding on hand mounted tires for 20+ years. Never balanced one and never had a problem. My bikes ride smooth and tires last as long as the next guys. I just match the sidewall dot up with the valve stem and mount it.
+1. I'll generally give it a few spins by hand before I put it on the bike just to make sure it doesn't stop at the same place, but I've never had to add, remove or move any weights.
Old Jun 22, 2009 | 02:23 PM
Sharknose's Avatar
Sharknose
Originally Posted by Uncle Scrooge
Second this. It is almost impossible to hold the spacers in place while you are trying to lift the tire and push the axle through.
Aw, come on..that would take all the fun out of it!!
Old Jun 22, 2009 | 03:11 PM
Bikerdad61's Avatar
Bikerdad61
Default Redneck Bead Breaker
Here is the way to break the tire bead. It works to. Used this method several times.
http://www.webbikeworld.com/t2/bead-...ad-breaker.htm
Old Jun 30, 2010 | 02:15 PM
mayfly's Avatar
mayfly
that is an awesome idea ! my indy only charges $25 to swap and balance a tire also... but that's a case of beer I can save
Old Jun 30, 2010 | 03:30 PM
nevets61's Avatar
nevets61
What xxxflhrci said.... I've always mounted my own.. been riding 35 years.. and in 35 years only got one bad tire that was out of round.. the rest I never balanced and they all rode fine. Go buy you a set of tire irons and take your time.. well worth it. BTW... don't use soapy water to lube the tire for mounting as it leaves water inside your tire which can corrode the aluminum rim... use a light film of vasoline on the bead, which will absorb into the tire...
Old Jun 30, 2010 | 03:39 PM
piasspj's Avatar
piasspj
Damn, if the OP hasn't got that tire changed by now I'd recommend taking it somewhere.
Why loose another year of riding over a hundred $$$.
Old Jun 30, 2010 | 03:51 PM
Wassup8687's Avatar
Wassup8687
ROFL. Now that is funny. lol
Old Jun 30, 2010 | 04:18 PM
Baffler1's Avatar
Baffler1
This is a really good post - great info!
archergodwin
Sep 17, 2016 08:55 AM
hamfxd
General Topics/Tech Tips
May 31, 2013 03:28 PM
jpace024
Feb 29, 2012 11:20 PM
jm1211
Feb 7, 2010 02:16 PM
rkc9999
Feb 27, 2007 11:45 AM
