I am STOKED!
Old May 19, 2006 | 01:04 PM
Blue SOG's Avatar
Blue SOG
Default I am STOKED!
My parts are in (at the dealership) and my appointment to drop the scoot off in now set... Tuesday! I'll pick it up Thursday evening just in time for a Memorial Day weekender!
95" Big Bore kit
SE Performance heads
SE 211 cams
Break-in will be done just in time for Americade and on to another tour of the Great Smokey Mountains!!!!
Old May 19, 2006 | 01:14 PM
Kess's Avatar
Kess
Default RE: I am STOKED!
CONGRATS DUDE!!!! - Bike is gonna fly! -I wonder if it will see the road up at the water gap that weekend???????
Old May 19, 2006 | 01:22 PM
CopDaddy's Avatar
CopDaddy
Wanna trade?
Old May 19, 2006 | 01:25 PM
100thRK's Avatar
100thRK
Are you doing the high compression pistons? Great combo with 211's. Got to mess with compression release but worth the bucks!!!
ORIGINAL: Phil
95" Big Bore kit
SE 211 cams
Old May 19, 2006 | 01:27 PM
Blue SOG's Avatar
Blue SOG
Kevin, it'll see either Rt 32 and 611 up to the gap then my favorite RIVER ROAD or the winding hilly 896 to Lancaster County. Those roads should be great for the "break-in". We've been to Lancaster Co. several time this year already and only been to the Gap once so far so that's probably where we'll go. Wanna join us?
Sorry Cop... no trades
I've been going over and over the build with my service manager. We settled on the std compression with the SE heads due my riding style. I rack up high milage and tour a lot. Around 20K a year or more 2 up fully loaded. [&:]
Old May 19, 2006 | 01:29 PM
bountyhunter's Avatar
bountyhunter
[sm=icon_cheers.gif] An envious thumbs up to that solid combo!
Old May 19, 2006 | 03:38 PM
Bruce00's Avatar
Bruce00
Which heads did you go with?
The
16925-02B or
16933-99B
Iam trying to decide right now myself. But Iam going with the hi compression pistons for a little more umppppppppppp up top
Good Luck with your set-up
Old May 19, 2006 | 05:29 PM
Topper's Avatar
Topper
Congrats! Good luck with the build, you are gonna love the combo. Gonna add the heads myself this winter.
Old May 20, 2006 | 10:58 PM
Bruce00's Avatar
Bruce00
**Bump**
Still looking for an answer on the heads
Old May 21, 2006 | 12:05 PM
PhilM's Avatar
PhilM
Bruce - be sure to check & see what the optimal compression ratio for the 203's is before you go bumping up the CR too high. It's REALLY easy to create a pinging / detination problem. My guess is that the heads used in this build were the S/E "Performance Heads" (NOT the HTCC heads - the HTCC's really don't get happy on motors <103CI). If you use the S/E Performance Heads & High Compression pistons, you'll have ~10.5:1 CR. That's pretty high! I seriously doubt the 203's will like that much compression (espically since they are sold as "bolt-in" replacements).
How's the fuel scene up there in Linden? You'll need 93 octane FOR SURE, and the jury is really still out on how all of our fuel is gonna support our hot motors with the new ethanol mandates. At least you're far enough north that typical temps are not too high, which is another enemy of high compression.
One last thing b4 I jump off my soapbox... be prepared to replace some starter clutches! If the motor ever kicks back while starting (w/10:5.1), you can bet starter clutch problems are not too far away.... Been there LIVED that. Trust me IT SUX! At least I could push start mine, it was not EFI. But it never happened less than 500 miles from home ~ ONLY on road trips..... [:@]
Stepping off the box now.
Did you ever consider getting your heads cleaned up (~$300 from BigBoyz) and using the stock heads instead of the the S/E heads (~$1000 from HD)? It is highly likely that you'll get "more for less" going that route. And.... people can't even tell by looking at the motor that is not "just another Twin Cam"....
Good luck!
