Reserve tank Question
Old Jul 1, 2009 | 08:24 PM
bdp's Avatar
bdp
Originally Posted by BOSTONFATBOB
On the odometer when tank tells me its 39r is that 39 miles to reserve or 39 miles to empty?
xxR is the amount of miles till the light and Lo comes on. At that point I need 5.25 gallons in my 6 gallon tank.
Old Jul 1, 2009 | 08:38 PM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
at 10 miles remaining.I get the "lo" warning,,,,,9 miles later I filled up,,,,,,,,,it took 5 gallons, there ya have it
Old Jul 1, 2009 | 08:57 PM
jberg's Avatar
jberg
r stands for "range". There is an r value when full too if you push the button until it comes up. Most vehicles' fuel gauges register empty a bit early as a margin of safety.
Old Nov 14, 2020 | 08:06 AM
Chattenhofr's Avatar
Chattenhofr
Stage I
Default 39r
Originally Posted by kingkingking
Mine said 40 km to go and I ran out of fuel. Its pretty useless really.
8k =5 miles, (approx) so 40 km = 20 miles, I would say that is pretty close to accurate.
Old Nov 14, 2020 | 06:40 PM
Bone Doc's Avatar
Bone Doc
Welcome to the forum from central Texas.
That is pretty close to accurate today just as it was 11 years ago when kingkingking posted that.
Old Nov 14, 2020 | 06:56 PM
son of the hounds's Avatar
son of the hounds
Once you learn it on your bike, it is a very useful tool. Much better than the fuel gauge. I have about 45-50 miles left when mine comes on, some have as little as 35 miles. It does not really matter, once it comes on and you refill your bike, you will know your bike. My average may not match yours. I get two up touring, about 43 mpg. So, mine comes on I have slightly more than 1 gallon left. I have gone 50 miles and added 4.7 gallon.
It is not accurate per say, but it is good enough to serve you well for riding.
Old Nov 14, 2020 | 07:50 PM
470004's Avatar
470004
39r=after 39 miles, start pushing.
Old Nov 15, 2020 | 07:17 AM
btsom's Avatar
btsom
Yes, miles remaining to a dry tank. However, it is a calculated value based on the recent average fuel consumption so your actual distance to a dry tank will vary. I am entertained that miles remaining will increase when going down a long hill even though no fuel has been added to the tank. It will also decrease way out of proportion to distance traveled while climbing a hill due to the increased fuel consumption. As a life-long professional pilot, running out of fuel is never an option and that carries over to my ground vehicle operation. Unless you are in unfamiliar territory and don't know where the next fuel opportunity is, I don't know why you would allow the fuel to get that low. These machines are too big and too heavy to push that last 100 feet to the pump. MAKE the time to fill up long before fuel gets that low and stop stressing over this stuff.
Old Nov 15, 2020 | 07:35 AM
Dynamick's Avatar
Dynamick
Actually 40 km is pretty much 25 miles, but who's counting when you're pushing a bike that's out of gas?
Old Nov 15, 2020 | 07:48 AM
Dseago1969's Avatar
Dseago1969
My 2011 RKC actually has 2 fuel gauges and will display miles remaining, but it’s all served by the same sending unit in the tank. I reset the trip odometer when filling and plan for 200 miles per tank.
