Is this normal?
Old Jul 1, 2009 | 08:10 PM
sjjshide's Avatar
sjjshide
Stage III
Default Is this normal?
Have a '08 Street Glide w/ approx 4500 miles. When I shift into 5th, notice a high pitch "whine". Is this another stigma for the Street Glide, or should I get this checked out? Thnx
Old Jul 1, 2009 | 08:12 PM
cdestuck's Avatar
cdestuck
ya better get used to it, it aint going away!!
Old Jul 1, 2009 | 08:13 PM
Kielbaso's Avatar
Kielbaso
Normal, don't worry about it. You never heard it till 4500 miles?
Old Jul 1, 2009 | 08:51 PM
scoteh's Avatar
scoteh
Look at it this way, you'll always know when you 're in 5th gear. I've gotten to where it is a welcome sound.
Old Jul 1, 2009 | 08:58 PM
sifularson's Avatar
sifularson
Believe it or not . . . I'm actually going to give you some constructive advice . . .
Change your transmission oil to Redline transmission oil with shockproof. I was using Amsoil which is excellent oil but I noticed a difference as soon as I changed. Give it a try.
The whine in 5th is a product of the straight cut gears that are used for 5th. All the other gears are helical cut to eliminate any noise. It is normal to hear some noise. If your drain plug magnet has a little fuzz, everything is OK. If there are larger flakes, take it to a dealer ASAP.
Check this out for info on helical gears: http://science.howstuffworks.com/gear3.htm
Check this out for straight cut gears: http://science.howstuffworks.com/gear2.htm
This is the oil you want:
http://www.racerpartswholesale.com/p...cycle_Gear_Oil
PS - welcome to the forum. The search feature and the knowledge base are awesome here.
Old Jul 1, 2009 | 09:01 PM
EasternSP's Avatar
EasternSP
I think that I have heard somewhere that the whine is intentional so you will know when you are in 5th. Sometimes ya don't want to lug the bike in 6th.
Old Jul 1, 2009 | 09:02 PM
tibadoe's Avatar
tibadoe
I hear its cause 5th is a straight cut gear.
Old Jul 1, 2009 | 09:04 PM
gunner11's Avatar
gunner11
"Normal", it will get quieter.
Old Jul 1, 2009 | 09:06 PM
StreetGlider56's Avatar
StreetGlider56
That's why there called Geezer Glides, As you age, the noises go away...
Old Jul 1, 2009 | 09:17 PM
gary_montague's Avatar
gary_montague
went away with the 75-90 mobil 1 gear lube
