Glide won't Start !@#!%$
Old Jul 23, 2009 | 07:16 PM
Wassup8687's Avatar
Wassup8687
Originally Posted by StreetGlider56
Not to be a SA but have you flipped the run switch to run?
He posted that he got it running.
Old Jul 23, 2009 | 07:41 PM
HDPursuit's Avatar
HDPursuit
Checked the gas too
It's not up yet. Sensor is testing bad. I'll check the coil in the am.
Still want to verify the ohm test for the sensor.
jdreed520-Thanks for the coil test. Which manual did you look that up in? Mine didn't say diddly about coil testing. *&%&$^
Old Jul 23, 2009 | 07:50 PM
jdreed520's Avatar
jdreed520
Originally Posted by HDPursuit
Checked the gas too
I also have a clymers manual....it is in there....
Old Jul 23, 2009 | 08:27 PM
HDPursuit's Avatar
HDPursuit
ARRGGHH A Hundred + in Harley manuals, and clymer has it!!!
Does it happen to have a CPS test?
Thanks again,JD
Old Jul 23, 2009 | 09:00 PM
jdreed520's Avatar
jdreed520
Thanks again,JD
Did it through any codes? The book says code 41 is crank sensor and 42 is cam position sensor.
for the crank sensor it says you should have 1 vac minimum at the CKP....
While cranking the engine then if it does then check continuity between pin 3 on the connect back to the other end at the computer, if it does you have a broke wire.
I hope this helps.
Old Jul 24, 2009 | 06:48 AM
HDPursuit's Avatar
HDPursuit
Alittle early here, getting ready for work.
Are you using the method of jumping the two pins on the diag plug to get the codes? I've ran across a couple of methods, not sure which is for my scoot.
I'll be looking for the clymer's manual this weekend(have to work)
Thanks again, I'll update when I've got a chance.
Old Jul 27, 2009 | 04:03 PM
HDPursuit's Avatar
HDPursuit
Talking
BIG GRIN!!!!!!!
Tackled the CPS this am. The new one ohmed at 1k, the old 5 M ohms. Except for some hassle with the oil filter. I have the HD Premium Oil Cooler, the adapter plate kept wanting to spin and the cheap *** oil filter wrench didn't want spin the filter! Worked out as I was able to move the oil filter outa the way to get at the sensor. Searched on how to get the Deutsch plug apart, tied Kite string to the wires and pulled the old sensor harness out. Tied the new sensor to the kite string and pulled it back thru!
Somedays I'm just FRIKIN BRILLIANT
Put the plug back together, a wire tie.....and ridin in 80 degrees and dodging the monsoon's (Thunder storms).
THANK YOU JD and the HDForums
n4rombl
Apr 7, 2019 08:28 PM
Dylanhaynes0412@gmail.com
Jul 14, 2018 02:28 PM
T07Bagger
Jun 3, 2018 12:39 PM
JeepBlk37877
Apr 7, 2017 07:57 PM
BigLuke
Nov 9, 2006 11:25 AM
