05 Super Glide died
Old Jun 3, 2018 | 12:27 AM
T07Bagger's Avatar
T07Bagger
Stage IV
Default 05 Super Glide died
So my buddies '05 Super Glide died while we were out on a ride. It was like the key was turned off. He killed the battery trying to start it be for I could check it for spark. Trailered it home, charged the battery & it ran great for a couple of 5 mile rides. No trouble codes listed. He goes to take it home & it won't start again. No spark. No trouble codes. Any idea what to check first?
Old Jun 3, 2018 | 02:10 AM
JohnMn's Avatar
JohnMn
Check primary battery connections, aka; follow them from battery to the starter and ground. A tiny bit loose anywhere in the connection will cause problems.
Old Jun 3, 2018 | 03:50 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up
+1 Definitely the Right Place to Start Before getting into spending any money ..
Old Jun 3, 2018 | 04:42 AM
Campy Roadie's Avatar
Campy Roadie
Check all of the above first, then look at the Crank Position Sensor. If that checks out ok, test the compression on the rear cylinder.
Old Jun 3, 2018 | 12:25 PM
nevil's Avatar
nevil
Charge the battery fully and get it load tested. In addition to the above suggestions.
Old Jun 3, 2018 | 12:39 PM
misfitJason's Avatar
misfitJason
Charging system!
Crittenden
Electrical/Lighting/Alarm
Aug 28, 2018 10:22 PM
GLS45
Nov 8, 2016 06:35 PM
rsingletary1
Dec 21, 2009 08:28 PM
HDPursuit
Jul 27, 2009 04:03 PM
BigLuke
Nov 9, 2006 11:25 AM
