Glide won't Start !@#!%$
Old Jul 18, 2009 | 01:57 PM
HDPursuit's Avatar
HDPursuit
Default Glide won't Start !@#!%$
Hey Folks, 02 Police Glide sits overnite and won't start. Sometimes. Othertimes starts fine.
Cranks over fine, not even a cough.
Top off gas,won't start.
Push Start-it %$%$% Runs Great.
My Lady is giving me SH** cause her snortster always starts.ARRGGGHHH.
How about a hit list of things to check?
Old Jul 18, 2009 | 03:40 PM
hawg50's Avatar
hawg50
check the ground at the battery.
Old Jul 18, 2009 | 06:34 PM
HDPursuit's Avatar
HDPursuit
Double checked all batt. connects, clean amd tight.
I can't figure out why push starting it works.
Old Jul 19, 2009 | 12:01 AM
mp's Avatar
mp
Last time I had a deal like that, it was the battery. Don't know if it was a bad cell or what.
Old Jul 19, 2009 | 10:35 AM
HDPursuit's Avatar
HDPursuit
You folks were RIGHT! Removed batt. checked grounds (loosened and tighten)
Install batt. PRESTO!
Thanks folks, were off to the Grand Canyon this am.
Old Jul 23, 2009 | 09:49 AM
HDPursuit's Avatar
HDPursuit
Hey Folks, Back Again ARRGGHH
Went to go for a morning ride yesterday, and the same sh$$ again. Got PO'd and pulled the batt. and went to town for testing. Got a new batt. installed and same. Cranks, no fire. Charged the batt. to 100%, still won't start.
No hill around here, so I can't try the push start.
PCIII has power.
Fuel Pump cycles.
Power to rest of bike.
Just won't fire.
Had Problems last year with a main breaker recall. Bike would cut out while running. Could I be playing in the same park again?
Old Jul 23, 2009 | 09:52 AM
jdreed520's Avatar
jdreed520
Are you getting power to the coil?
If not check the fuses and breakers....
Just my .02
Old Jul 23, 2009 | 11:34 AM
HDPursuit's Avatar
HDPursuit
Checked all fuses, OK
Pulled spark plugs, tried turning it over with the spark plug grounded. Saw a spark but it didn't seem strong or consistantly sparking.
How large should the spark be? Where to ground it? To the fins or head bolt?
Fuel line is being pressurized. How can you tell if your getting fuel w/ an EFI?
Spark plugs were dry when I pulled them.
Wanted to ride today, not scratch my head and wrench.
Old Jul 23, 2009 | 11:40 AM
msbhvn's Avatar
msbhvn
My problem twice was a bad crimp on the ground wire which intermittently worked. First time thought it was a fluke, loose in the crimp replaced and had another problem touched the wire and it was hanging barely at the end of the eyelet. Wire came off in my hand.
Old Jul 23, 2009 | 12:39 PM
troy.j's Avatar
troy.j
Have you had the battery tested? if not, do that. Next, replace your battery cables.
