PC5 Problem?
Old Jul 19, 2009 | 06:48 AM
UALCapt's Avatar
UALCapt
Default PC5 Problem?
'09 FLHTP with PC5 bogs down at anything more than 1/3 throttle. Just finished a 1600 mile ride up to Northern Maine and have some real issues!
Here are symptoms ...
* Uneven idle after cold start (pulses ea 3-5 seconds between 900-1200 rpm) No fault codes.
* Below approx 4000 rpm (in all gears), the engine bogs down completely at anything greater than 1/3 throttle opening. Twisting the throttle produces intake and exhaust noise, but NO power. Can't go up a slight incline at more than 55 mph.
* Above approx 4000 rpm, she runs fine at any throttle setting. This indicates to me that there are no problems with fuel delivery (ie, pump, filter, injectors, etc).
* Problem has been present since I installed the PC5 last month. I initially thought it was caused by moisture I found in the PC5 harness connectors, but after drying and applying dilectric grease, the problem persists. Could liberal amounts of dilectric grease be causing shorts between the pin connectors like moisture would?
I'm scheduling an appointment with a great dyno-tuner at Black Hills in NJ. In the meantime, any suggestions?
Thanks!
Old Jul 19, 2009 | 07:02 AM
Mr. Wizard's Avatar
Mr. Wizard
Unless you installed or set it up incorrectly, which I highly doubt, you have a bad PCV. You'll have to send it back to Power Commander for a swap out. I"m not knocking the PCV but this is not the first thread about one giving the rider fits.
Old Jul 19, 2009 | 07:54 AM
rjmac53's Avatar
rjmac53
let us know what the problem was...
Old Jul 19, 2009 | 04:45 PM
iclick's Avatar
iclick
Check and make sure none of the connector pins are belt or otherwise not making good contact. Another forum member had a similar problem with their PCV recently and this was the source.
Also, try removing the PCV temporarily and see if the problem persists.
Old Jul 19, 2009 | 05:39 PM
UALCapt's Avatar
UALCapt
Pins are all straight, no moisture, and connect well. Going to call Fuel-Moto tomorrow to get their take on it. Very strange. I'll try the disconnect though, thanks.
Old Jul 19, 2009 | 06:11 PM
nvsteve's Avatar
nvsteve
Do you have to zero the throttle position on the new bikes?
Old Jul 19, 2009 | 06:19 PM
Clint55's Avatar
Clint55
I guess we can assume that you installed both of the O2 eliminators.
Also, just thought, but do you have other bikes or have you ever had a PCIII with the software already installed on your laptop? I had that problem and found that a software conflict resulted in the wrong map being downloaded. The fix was to uninstall the PCIII software and reinstall the PCV software.
Old Jul 19, 2009 | 06:57 PM
acchd's Avatar
acchd
If your hareware is sound then it sounds like wrong map. Call FM Monday great people and will work with you.
Old Jul 19, 2009 | 07:43 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
These are very interesting issues which we have never seen with the PC-V and I am certain it is not the map unless the OP has changed from what we provided. A possible issue may be the throttle position settings which may have been reset incorrectly. I recommend plugging in the PC to the USB software, starting the bike and getting it up to operating temp and checking the closed throttle position also noting the % value which will move as you rev the throttle. Please give us a call and we can help out and if needed we can get the unit back and test it on our 09 bike.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jul 19, 2009 | 09:05 PM
iclick's Avatar
iclick
Jamie brings up a good point on the TP setting. If you click on Reset with a TBW bike the TP setting will be far off base. While the bike is running and the PCV connected to the computer, go to PC Tools > Calibrate > Throttle Position and look at the voltage readings. They should read near the following, and if not enter these values:
Closed throttle 0.700 (Minimum Voltage)
Open throttle 4.300 (Maximum Voltage)
