I still need your input here
Old Jul 20, 2009 | 10:42 AM
2whlr4life's Avatar
2whlr4life
Arrow I still need your input here
I posted this in the 'Dyno numbers section' nothing yet. I'm reposting it as a new thread here.
My bike a 2007 RoadGlide with a FatCat 2 into 1 pipe with the quiet baffle. S/E air cleaner (K/N filte). Power Commander III from Jamie/FuelMoto. Dyno run;
Max Power= 73.93 h.p. Max Torque= 86.42
Happy with those results.
My problem. After reading, researching just cam upgrades I settled on an Andrews 26H with S/E adjustable pushrods. An Indy did the work. Dyno #2
Max Power= 84.10 h.p. Max Torque= 89.03
A nice increase in h.p. But, I bought the cams for a torque increase in the 2000-5000 rpm range where I spend most of my time. I really don't feel a difference after the cam install. I don't think the second dyno tune is as good as it can be. Agree or disagree? It looks like the torque dip from 3300-3800 rpms maybe the culprit. I wasn't able to look over the shoulder of the tech guy so I don't know the Air/Fuel ratio. Should I take it back or look for a different tuner? Thanx so much for your input.
Old Jul 20, 2009 | 10:48 AM
Ribitt's Avatar
Ribitt
Well here are my numbers for my 07 ultra with rinehart TD's, SERT, SE A/C S&S gear drive and the Andrews 26 cam
Old Jul 20, 2009 | 10:52 AM
ranger56528's Avatar
ranger56528
I think with a 26 your going to notice the differance with 2 on the bike and its more of a low- mid range cam as in will make passing a little better....1800-5200,21 will give ya a lower rpm torque but not much.
Iam leaning twords S&S 520 cams............
Old Jul 20, 2009 | 10:59 AM
2whlr4life's Avatar
2whlr4life
Arrow thanx Ranger
I agree with the rpm range, it looks like the dyno has a bit of a flat spot in the area I was hoping for an increase. It's hard to read my chart I know.
Old Jul 20, 2009 | 11:00 AM
timvan's Avatar
timvan
woods 6-6 if you can get over a little noise!
Old Jul 20, 2009 | 11:24 AM
Marsh's Avatar
Marsh
I think the 26A would have been a better choice for low RPM power. Doesn't the H stand for high lift? That mean more power at higher rpm's.
Marsh
Old Jul 20, 2009 | 11:56 AM
6 gun's Avatar
6 gun
ask this question in the engine/fuel/intake/exhaust
section to get the answer you are looking for
Old Jul 20, 2009 | 01:31 PM
2whlr4life's Avatar
2whlr4life
Arrow Good idea
Will do that. My time b4 Sturgis is short and if I go back to that Indy, I don't want to wait very long to get it done.
Old Jul 20, 2009 | 01:33 PM
2whlr4life's Avatar
2whlr4life
Default chain vs. gear drive
Originally Posted by Marsh
I think the 16A would have been a better choice for low RPM power. Doesn't the H stand for high lift? That mean more power at higher rpm's.
Marsh
I thought the H meant a stock chain replacement drive vs. a gear drive setup.
drew4jan
Apr 5, 2012 08:09 PM
wildeano
Jan 6, 2010 10:51 PM
wildeano
Nov 23, 2009 05:59 PM
harley-jones
Nov 20, 2009 04:14 PM
msh134
Dec 15, 2007 03:45 PM
