Soos-Kits Footboard Extensions Will Ring Your Bell...
Old Aug 11, 2009 | 02:52 PM
Wassup8687's Avatar
Wassup8687
Originally Posted by Magnus
I'll be ordering a set today for my new to me '08 FLHX. My size 13s just don't have enough room for comfort. The heel shifter will be going soon as well. Also may try to find a smaller brake pedal as I typically only use the hand brake anyway.
The Soos extensions will be a huge help.
If you remove the rear shifter make sure you carry it in your bag in case you need it in an emergency.
Old Aug 11, 2009 | 09:56 PM
soos's Avatar
soos
Removing your rear shifter will also leave a void on the shift shaft which will have to be made up with a spacer. There are some after market pieces available.
Old Aug 12, 2009 | 09:48 PM
soos's Avatar
soos
Bump to the front.
Old Aug 13, 2009 | 09:47 AM
Magnus's Avatar
Magnus
Just received the shift spacer today and removed the rear shifter. Tossed it into the tool bag as suggested. Man, I hope I don't ever need it though! Looking forward to the SOOS floor board spacers. My heel keeps slipping off the right side when I rest my toes on the highway pegs.
Old Aug 13, 2009 | 11:11 AM
Wassup8687's Avatar
Wassup8687
Talking
Mine did too. With the Soos Extensions you'll be just fine and able to rest your heel comfortably.
Old Aug 13, 2009 | 09:59 PM
soos's Avatar
soos
Hey Magnus, the Rider's Kit should definately help with that problem.
Old Aug 14, 2009 | 07:30 AM
dawg's Avatar
dawg
The spacers also help if you have an extended air cleaner like I do (zippers taller air filter element) to allow your feet to be out farther.
Old Aug 15, 2009 | 08:07 AM
Wassup8687's Avatar
Wassup8687
I can imagine how much more comfortable it would be with a larger aftermarket air cleaner. It's so much better even with the stock!!
Old Aug 15, 2009 | 10:20 AM
Wassup8687's Avatar
Wassup8687
Hey Soos, Will the passenger floorboard interfere with using a center stand?
Old Aug 15, 2009 | 10:37 AM
soos's Avatar
soos
No, there should be no interference with that application. The passenger brackets are situated up and away from the undercarriage where the center stand is located.
