I bought the Harley Davidson touring pull back handle bars for my 07 FLHX - part number 55914-98. I know I'll need new mirrors, but I'm not sure what cables I'll need. I've called four different dealerships to ask what if any cables need replacing. I've received 4 different answers. I can't tell you how frustrating this is.
Can someone that has these bars installed on a 2007 or earlier FLHX tell me exactly what additional parts I need? I'd like to keep all the cabling going through the fairing to keep a clean look.
I got this out of the new 2010 parts book. page #593. I would suspect you won't somthing different then standard black lines so this is the #s for the diamond back lines. It shows all batwing bikes but the street glide. I would think it would fit the street glide though.
I did it and the only cable I had to replace was the clutch cable. You can use the stock one if you route it outside of the fairing but I like it mostly hidden. I think it was +3.
Part Number
Tip to Tip
Base Width
Rise
(inside)
Pull Back
Knurl
Center to Center
Rise
(Tip-to-Base)
(outside)
55914-98
30.75"
15"
8"
7.5"
3.50"
12.25"
Above is the new pull back measurement
56625-99 30.25" 15.75" 7.25" 6.25" 3.48" 9.75"
Above is the standard measurement
The new pull back handler bar should be about 2.5" taller. Your hands should be about an inch or some about the fairing. What is the part number of your handle bars?
