75W-90 versus 75W-140
Old Aug 7, 2009 | 12:24 PM
Bowhunter61's Avatar
Bowhunter61
Default 75W-90 versus 75W-140
OK, before you blast me I did try the search using the title and variants but I got several hundred hits and wading through them would take forever to find the answer.........if it is even in there.
I went to an Indy to buy some Amsoil Sever Gear and he said to use 75W-90 in the tranny but I see a lot of guys on here use 75W-140. So what's the Pro's and Con's between the 2? Do both meet the recommended by Harley? I looked my service manual and it states use HD PART# xxxxxxxx, that didn't do me any good.
Old Aug 7, 2009 | 12:38 PM
oricko's Avatar
oricko
I use 75w-140 in my 06 it makes shifting smoother and quiet
Old Aug 7, 2009 | 01:11 PM
bagman1's Avatar
bagman1
The thicker viscosity grade oil would be better for higher mileage trans and those that have more wear. Thats the reason for thicker oils in the first place.
Old Aug 7, 2009 | 01:56 PM
Clint55's Avatar
Clint55
I use the Amsoil 75-140 and it works great. A HUGE improvement over the HD Part No. you mentioned. I've learned that HD reccommends a lot of things that are good for them and not necessarily for me or my bike.
And if anyone ever blasts you for not using the search the way they would like you to, don't sweat it or just blast back. If they would have done a search about blasting people for not using the search feature they would find that most of us don't care and suggest not reading threads if you don't like them.
Old Aug 7, 2009 | 02:05 PM
albertasaurus's Avatar
albertasaurus
I use Amsoil 75W-90 in mine, and right away noticed quieter 5th gear and smoother shifts. Next time I change out the tranny oil, I'm going with the 75W-140 just to see if it makes much of a difference.
Old Aug 7, 2009 | 02:11 PM
Clint55's Avatar
Clint55
Another quick note is that I have also heard a lot of positive comments on Redline Shockproof. I think I'll give that a shot on my next tranny juice swap just so I can compare it to the Amsoil.
Old Aug 7, 2009 | 04:29 PM
Cheiron's Avatar
Cheiron
Both of them will give you about the same cold / cool weather performance.
The 75w140 was developed for heavy gear loading and provides greater film strength when hot. Because it is thicker when hot it does provide better cushioning to the gears, which is why some notice that the 5th gear whine is reduced and the shift clunk is less noticeable. The other side is that fuel mileage may suffer a bit, if you worry about every last MPG.
When rebuilding, the only time I have noticed any difference in gear wear is when the gear box is normally loaded heavy and runs hot.
Justin
Old Aug 7, 2009 | 04:56 PM
Beemervet's Avatar
Beemervet
75-90 is a major improvement over any motor oil. The only thing about 140 is a higher running temp.
Old Aug 7, 2009 | 05:55 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
...So what's the Pro's and Con's between the 2?...
Both will do well and flow the same at cold-start temps but the w140 stuff will take on the properties of a thicker oil at higher temps.
Old Aug 7, 2009 | 09:18 PM
Ozoneman's Avatar
Ozoneman
I use the Amsoil 75W-110. That's a happy median. You get a thicker oil but not too thick.
From what I've been told viscosity numbers for gear oil are not comparable to motor oil numbers. I've been told that 20W-50 motor oil has about the same viscosity of 75W-90 gear oil. So using 75W-90 gear oil is the same as using the 20W-50 motor oil as far as viscosity. I figure using the 75W-110 gives me a little thicker oil but not so thick that it could reduce mpg.
BTW, I do notice a difference in the trans as far as noise when shifting is less and it shifts real smooth.
