Another exhaust question
Old Jun 1, 2006 | 09:46 PM
RKC2001's Avatar
RKC2001
Default RE: Another exhaust question
Much clearer, thanks. I appreciate the feedback.
Old Jun 1, 2006 | 11:59 PM
ILSRWY6's Avatar
ILSRWY6
Dr. Bruce - I assume
Impressed - I had to read it twice. I think I understand now.
Will there be a test on Friday?[sm=bounceybounce.gif]
Old Jun 2, 2006 | 12:14 AM
txfxstrider's Avatar
txfxstrider
ORIGINAL: bountyhunter
For sure lose the stock headers and go with a dual, or 2 into 1 system. For duals, Hard Krome (below), no clamps or slip-ons, fantastic performance, sound and looks. Favorite 2 into 1 would be, Bassani Road Rage. Your AFR looks lean compared to most!
For performance, the stock headers with free flowing mufflers are better than duals. A good 2 into 1 system is the best. If you want the look of duals with a very good 2 into 1, get the Thunderheader with falsie.
Old Jun 2, 2006 | 01:03 AM
Topper's Avatar
Topper
Bruce..........................[sm=hail.gif]
From what I've read and been told, 13.5 ATF is the number that will create the most HP out of a VTwin. Thus, when you look at various dyno charts, you will see a high ATF number in the lower RPM range 1500-3000, but that ATF number should level off from there to down in the 13's throughout the rest of the run. But on the other hand, if it aint popping, spitting and coughing, leave it alone, other than adding the Bassani's
Old Jun 2, 2006 | 03:43 AM
Bruce00's Avatar
Bruce00
Wait a minute, before I start getting questions....................
I have a couple of sites that I read up on tuning thru SCT for my truck. I just copied and pasted that info, thought it would be a good read and help members understand the a/f numbers better. But your right Topper, you want a different a/f number depending on throttle opening and rpm's. It's just easier to dial in a number accross the board and present a flat line on a dyno graph. But most of the a/f samplers on dyno's are dirty and haven't been cleaned/changed in a while, so really I don't put to much faith in dyno a/f numbers. I'd rather depend on a stand alone wide band to gather the info. I was told that the perfect a/f to look for was 13.2, so who knows
Iam just a old burnt out welder
Old Sep 18, 2007 | 06:39 PM
roadkingdave's Avatar
roadkingdave
I had a shop install true dual and re calibrate my sert. They dyno tuned it and told me the a/f ration should be around 13 ; 1 It runs fine but the mileage went from 42 to 34. I dont really care about the mileage I just don't want to stop for gas in 120 miles. Does this guy know what he is doing? I went with an independant shop because the dealer tuned the sert and it popped like crazy.
conn-e-rot
2014-2024 Touring Models
Feb 15, 2017 03:57 PM
TangSooDoMan
Jul 8, 2015 09:08 AM
13bob
Oct 30, 2013 10:40 PM
mhutch2
Jul 21, 2007 03:09 AM
jmbear328
Apr 18, 2007 10:29 AM
