Tourpak Latch Problems
Old Aug 15, 2009 | 12:29 PM
gandolf50's Avatar
gandolf50
5th Gear
Unhappy Tourpak Latch Problems
I have an 05 Ultra and have had to replace the latches about every 6 months. The only response from the dealer is they are willing to replace them for me if I keep buying the latches. It is frustrating that no one seems to have identified why some bikes continue to have problems and others do not. My failure mechanism is always the same. The threads shear off from the latch. It is obviously a weak point and would be an easy fix if the factory wanted to improve it. I wished someone made an aftermarket latch.
If anyone has any suggestions on what to try or perhaps what they have done to fix there problem I would appreciate it. They only option I believe I have at this point is to replace the bike and I do not want to go that route.
Old Aug 15, 2009 | 01:05 PM
unclzim's Avatar
unclzim
Made in china!!!
Old Aug 15, 2009 | 01:24 PM
dawg's Avatar
dawg
When are you having trouble, just going down the road or the actual opening and closing of them? If it is just while going down the road you may try and replace the hinges with the upgraded hinge kit and might help with the vibrations of the latches on the opening side.
Old Aug 15, 2009 | 01:39 PM
Skulmn's Avatar
Skulmn
Originally Posted by unclzim
Made in china!!!
Agreed...You want S*IT go to China...Doesn't get any crappier!
Old Aug 15, 2009 | 09:14 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Seems like the place for a good Confucius joke, but damned if I can come up with one.
Old Aug 15, 2009 | 09:21 PM
themensh's Avatar
themensh
Replace them with a latch from 2004. Mine seems to be doing fine.
You say "My failure mechanism is always the same. The threads shear off from the latch.",
but I'll be danged if I know what that means.
Replacing latches every three monthes does not even sound right....even with chinese crap. I might have to call B/S.
Old Aug 15, 2009 | 09:24 PM
1953riderforlife's Avatar
1953riderforlife
Are you talking about the latch or the hinge?
Old Aug 15, 2009 | 09:29 PM
kmoulds's Avatar
kmoulds
6th Gear
Gid day
I have an 03 Ultra and my latches have failed about 4 times in the life of the bike. I have found that when the small bolts did shere off it was because I have left them unlatched and I beleive that the vibration of the bike had something to do with it. Other than that they have been OK. Maybe try an 03 model latch, if they fit or if they are compatible.
cheers - Kym
Sydney AUSTRALIA
USAproud
Jul 2, 2019 05:23 AM
Bookie
Mar 20, 2017 07:43 AM
Geoff
2014-2024 Touring Models
59
May 11, 2014 08:32 PM
jburgess56
Jan 15, 2013 09:26 PM
radridd
Sep 30, 2007 08:58 PM
