Need light inside my TourPak
Old Aug 17, 2009 | 04:08 AM
Trailfndr's Avatar
Trailfndr
Originally Posted by ripper43
Tour-PakŽ Luggage and Saddlebag Interior Light Kit
54331-04
3-Light Tour-PakŽ and Saddlebag Light Kit
Fits '93-later Touring models (except Trike) equipped with rigid or detachable King or Chopped Tour-PakŽ Luggage.
MSRP US $119.95
I installed the three light kit, and it works GREAT. has automatic shut-off after 5 minutes so you can't leave it on and run down your battery. No batteries to change or to die when you most need them, they are right there where you want them to be at all times, and can't "Peel" off as they are bolted on. Install was quick and easy, takes about 30 minutes total. The Saddlebag lights work as well as the tour pack one so when you open the saddlebag, touch the light and it allows you to find anything in your bag.
I tried the cheap alternatives for a while, but I got damned tired of having to change batteries in the dark when I needthe light..so I did the job Right.
Old Aug 17, 2009 | 04:40 AM
Bad Pig's Avatar
Bad Pig
not for 120.00.......you know how many batteries you can buy for that???
if I have dead batteries in my cheapo LED light then I'll use my lighter to find what I'm lookin for till I replace em. theres too many other things I'd rather spend that kind of money on.
Just sayin.......
Old Aug 17, 2009 | 05:43 AM
ks-waterbug's Avatar
ks-waterbug
I bet we could build a set pretty close to the HD kit for under $40... That price would only be due to the cost of the factory connectors other wise I bet it could be done for even less. Anyone ever gave this a try?
Old Aug 17, 2009 | 07:23 AM
frenchbiker's Avatar
frenchbiker
Originally Posted by dawg
I use a stick on circular LED push light. It came from like WalMart in a package of 3 for dirt cheap. Works great and runs on a AA battery.
Sounds like the ticket. I'm gonna buy these 3 dot-it lights and add a key ring with LED to my fob as a back-up light and I'll be all set. No way I'll pay 120 bucks for the HD light kit. Thanks a lot.
Old Aug 17, 2009 | 08:39 AM
piasspj's Avatar
piasspj
I use the stick-on puck LEDS. I put them in the lid storage pockets, can take them out and use them wherever.
Old Aug 17, 2009 | 10:17 AM
bartb1200's Avatar
bartb1200
Same as Dawg works great
Old Aug 17, 2009 | 12:40 PM
frog13's Avatar
frog13
Hmmmm, let me do some math:
HD Kit $120
Puck Lights $4
If I use one set of puck lights a year and throw them away, I can go thirty years with puck lights for the same price as the HD kit. Yep! You guessed it, I've been running the puck lights now for the second season, same batteries, used heavy duty velcro to mount them ....
Old Aug 17, 2009 | 12:56 PM
RODEO's Avatar
RODEO
I use a small circular "stick up" L.E.D. light in each of my saddle bags and one in the tour pack too. Battery operated and inexpensive. Got mine at Walmart in the electrical section. I think about $5 a piece including the battery.
They look similar to this:
Old Aug 18, 2009 | 04:30 PM
vanlente's Avatar
vanlente
Stick on light from WallyWorld. I did put on heavy duty velcro and I think I used a little Gorilla glue to ensure the velcro stuck to the light. 2 years no problems < $10
Old Aug 19, 2009 | 06:01 AM
bull's Avatar
bull
I installed harley lights in/and under tourpack. Wired them up and they do not work! Going to Walmart
