Clutch adjustment
Old Aug 18, 2009 | 08:20 PM
cuda67bnl's Avatar
cuda67bnl
Originally Posted by FLoTR
Thanks Oinker2. I adjusted the freeplay in the cable this past Saturday to around .090(I'm **** like that). Today I pulled it to check it and it's got to be over .125 and the jam-nut is still tight. What gives Could the cable be stretching? It's got about 5300 miles on it.
Were your bars turned a different direction each time you checked it? In some cases your cable will be in a bit of a bind depending on how your bars are turned, and that can affect the play.
Old Aug 18, 2009 | 08:32 PM
FLoTR's Avatar
FLoTR
Thanks cuda, I'll adjust it with the wheel straight. I was going down the road today when I pulled on it so it was straight.
Old Aug 18, 2009 | 10:22 PM
Neckball's Avatar
Neckball
The critical adjustment is the allen screw, not the locking nut torque.
Maybe, until you have a lock nut back off and fall down in the primary when you're 75 miles from home (ask me how I know).
Old Aug 19, 2009 | 06:45 AM
Notgrownup's Avatar
Notgrownup
Unhappy
WOW!!! that would suck.....
badfl97
Aug 1, 2012 10:03 PM
DPete
Nov 1, 2009 12:47 AM
gli.der
Apr 1, 2009 07:14 PM
Kugie's HOG
Mar 13, 2009 09:34 PM
BluBob
May 27, 2008 01:03 PM
