88 cam Problems
Old Aug 19, 2009 | 12:25 PM
Firebike32's Avatar
Firebike32
Changed mine at 50K.
Old Oct 15, 2010 | 12:27 PM
gmc's Avatar
gmc
My friend (82 years young) wants me to look at an 06 SG w 36K miles on it. Did they improve the cam guides any between orig. and the 06. Any ideas on the average for this year?
Old Oct 15, 2010 | 01:53 PM
djl's Avatar
djl
The '06 SG has the same problem, spring loaded cam chain tensioners. Easy to check and easy to replace. I converted my '05 Deuce to gear drives when I increased displacement to 95" (new chain drive was not available or I would have gone that route) and they were wearing fine but the outer tensioner has a large crack in corner and the whole corner was about to come out. I bought an '02 FLHT with 25K miles on it and checked them the first thing. The outer was wearing normally but the inner was worn down to the metal carrier. This one was upgraded to the hydraulic tensioner/roller chain setup when I increased displacement to 107".
Yes, there have been failures but you must remember that there are only about a gazillion of them running around with no problems. If buying a used bike, I would go ahead and replace the tensioners wtih the stock pieces. Once the chain has been run a while and had been "polished" the wear on replacement tensioners should be normal. When changing them out, do not let the tensioner "slam" back against the chain when released; let the tensioner close agains the chain gently. The hard contact can chip or crack the surface of a new tensioner; the material is brittle.
The parts for the new hydraulic tensioner/roller chain setup run about $370 from Zanotti's. When you do change tensioners, change the inner cam bearing to Torrington B148s.
Old Oct 15, 2010 | 07:53 PM
gmc's Avatar
gmc
Thanks, I would have thought there would have been some improvement in a 6 year run.
Old Oct 15, 2010 | 08:46 PM
luckyhog's Avatar
luckyhog
2006 with SE 211 cams with 28k, had the dealer check the tensioners. They were slightly worn but I had the SE hydraulic kit installed just so I wouldn't have to worry about the tensioners for a while.
Old Oct 16, 2010 | 08:33 PM
TMair's Avatar
TMair
Had about 65K on mine when I had them replaced with the SE kit, mine where worn, but not worn out, I also had the cam bearings replaced.
Total cost out the door was right around 1K.
Terry
Two Lane Tramp
2014-2024 Touring Models
19
Jan 24, 2018 08:59 AM
howlmtn
Jun 24, 2014 09:48 AM
doug62
Oct 3, 2013 08:55 AM
gumshoe4
Dec 8, 2010 05:40 PM
Badlarry
Jan 30, 2010 12:43 PM
