Brake's squealing
Old Sep 5, 2009 | 10:21 PM
ks-waterbug's Avatar
ks-waterbug
squeaky brakes here as well, 08 Ultra Classic.... Next time I have the wheels off gonna try some brake quieting spray.
Old Sep 5, 2009 | 10:39 PM
badjustbad's Avatar
badjustbad
The rear brakes on my '08 squealed from day one. Makes the bike sound like a real junker and I'm almost embarassed to be seen on it.
I replaced front and rear with Lyndal pads and they were quiet - for a while. A fix that was suggested by another person on this forum is to clean the pads and put some grease (small amount - don't go crazy here) on the back of the pad where they contact the piston. I also sanded the rotors with fine grit sand paper and then I took a file to the leading edge of the brake pads to create a slight beveled edge.
This worked well for a few thousand miles, but I ride a lot and they are squealing again. Time for another service...
Sweetbaboo's Avatar
Sweetbaboo
I have an 09 EGC, and my rear brake squeals every once in awhile. I took it into my dealer and they had a service bulletin on it; they applied a paste that came in a kit to my brakes that quieted them down for a little while. This was done for no charge under warranty.
What works best for me now is a hard braking session once a month. I run it up to about 55 mph in 5th gear and apply a firm rear brake, staying on the throttle, until the speed drops to 45 mph. Then, I release the brake and let the speed run back up to 55 mph and repeat 3 times, all the while staying on the power/throttle, and my brake squeal is gone for close to a month.
Of course, I did stay at a Holiday Inn last night.
Old Jun 15, 2011 | 06:04 AM
Notgrownup's Avatar
Notgrownup
OK i know this is a old post but my question is....If they put left rotors on the right and vice versa then could i use 2 left rotors on my front wheel??? What are the adverse effects??? It's a lot easier to find left rotors that right ones... (Used ones) that is...
Old May 17, 2015 | 07:58 PM
pjwarneka's Avatar
pjwarneka
I have a 2014 883 that the rear break squeeks it had 9 miles when I bought it, and nothing has ever been removed. Front is OK, but the rear really squeals. ..... wait, it's a HOG right? so that is normal?
I have to admit, since I'm in the city, I notice how everybody even the person in front of me hears me stop at the lights... should I consider this a safety feature?
I wish I had a fix for it, should I do some hard stops to clear away the new surface?
Thanks in advance
oldtimer61
Dec 31, 2019 06:26 PM
128auto
Nov 5, 2009 11:41 AM
mdxd62
Sep 12, 2007 04:22 PM
Suburban28
Sep 9, 2007 11:58 PM
hdxl1200r
Aug 28, 2006 10:40 PM
