Missing spacer?
Old May 17, 2015 | 06:41 PM
Oldskewl's Avatar
Oldskewl
Default Missing spacer?
13 SG
Changing out the rear tire and now I'm unable to tighten the rear axle but without the adjusters turning. Seems like I have slop in the wheel?
Is there a spacer in front of the drive pully? Seems like there should be and mine is missing... Maybe rolled underneath something.
Old May 17, 2015 | 07:22 PM
Musician's Avatar
Musician
IDK about the '13, but every other bike I've had, or worked on has had a spacer on the drive side. Might I suggest that before you do anything else on your bike that you invest in a proper manual? Very good thing to have, but only if you actually use it. Good luck.BTW, I used to work at a bike shop until '08, so that's why IDK about the '13.
Old May 17, 2015 | 08:07 PM
jmn1960's Avatar
jmn1960
yes spacer on both sides ,,, better find it
Old May 17, 2015 | 08:16 PM
glcash's Avatar
glcash
There's a small spacer between the swing arm & the belt pulley.
johnod
EVO
Jul 26, 2014 08:10 AM
NiteOwl
Apr 14, 2014 09:34 PM
Rynb15
EVO
Apr 10, 2012 12:14 PM
randymac7
Oct 17, 2010 09:21 PM
haak30
Aug 19, 2010 05:37 PM
