E3 question
Old Aug 29, 2009 | 07:31 AM
dhubley's Avatar
dhubley
Here is what Dunlop says:
"We have checked inflation pressures at several touring rallies and found a high percentage of rear tires to be underinflated. In addition, weight checks of the rear axles of these motorcycles indicated a number of tires were loaded beyond maximum capacity."
"For touring motorcycle loading, follow these general guidelines:
Light loads-single rider with some luggage (up to 200 lb. total)-minimum tire pressure of 32 psi front and 36 psi rear must be maintained.
Heavier loads-dual riding and/or luggage (from 200 lb. total up to maximum motorcycle capacity stated in the owner's manual)-pressure of 36 psi front and 40 psi rear must be maintained.
Please Note:
For any dual riding or fully loaded use, 40 psi must be maintained in all Dunlop rear tires fitted to touring motorcycles."
http://www.dunlopmotorcycle.com/info....asp?id=31#tip
Old Aug 29, 2009 | 07:48 AM
hucks 08's Avatar
hucks 08
i here all the talk about the e3 ,what type tire is it . elite3 . what diff do they make
Old Aug 29, 2009 | 07:53 AM
vickon's Avatar
vickon
Bingo!! 36f/40r it'll be for our next 2-up trip ...as always you guys rock!
Old Aug 29, 2009 | 07:56 AM
vickon's Avatar
vickon
Hucks ....http://www.dunlopmotorcycle.com/tire...tire.asp?id=86
Awesome tires, positive difference is notable! Won't go back to 402s even if I can't get whitewalls on the E3, the benefits outweigh the aesthetics ...8]
Old Aug 29, 2009 | 07:58 AM
vickon's Avatar
vickon
BTW ...the 160/80-16 does fit on the rear ...God what a post ***** ...LoL
Old Aug 29, 2009 | 08:19 AM
iclick's Avatar
iclick
Originally Posted by Jinks
One morning I noticed a noise like a bearing howl coming from my rear wheel.
Gold Wing riders often mention a howl on cornering, and my rear E3 howls a bit on hard turns, not enough to be even the slightest concern, however. It now has 16k on it and I didn't notice it until recently. The straight-line howl I've been chasing for a year now has turned out to be a bad bearing in either the primary or tranny and will be dealt with next week. At one time I blamed that on the tire, then the belt, neither of which was the culprit.
As for pressure, I'm running 37F/40R cold, same as I always ran on the D402's.
Old Aug 30, 2009 | 10:23 AM
hucks 08's Avatar
hucks 08
i have 10000 on my tires now ,after the next road trip im having them changed .i guess ill try the e3's
Old Aug 30, 2009 | 10:33 AM
vinnieee's Avatar
vinnieee
Originally Posted by txfxstrider
I'm running the same as in my 402s, 36 front and 40 rear. I run these pressures all the time whether solo or two up.
I'm running the same.
Old Aug 30, 2009 | 06:05 PM
mastery's Avatar
mastery
+3. 36/40 here as well.
Old Aug 30, 2009 | 08:02 PM
glide2005's Avatar
glide2005
Hey Hucks, go to www.cyclegear.com for your EIII. They have a 20% sale right now. Both tires, front and reat for 98 bux each, and with the 20% off, the're are 176 bux. And only 8$ per tire shiping.
