Fuel problem?
Old Sep 17, 2009 | 04:23 PM
tenn.vol.'s Avatar
tenn.vol.
Head temp. sensor was my thinking also, as my 97 FLHRKI had some of the
same symptons plus some. It would set a code most of the time. Bought a
code reader from one of my stealers, after the other said that was a stealer
item ONLY and I could not purchase it. One LED light, and $50. later it was
mine. Code came back to head sensor.
A couple or three yrs. ago, about a HD (hundred dollars)
After reading the book, said to raise the tank. NO THANKS!
I used a pair of hemostats and a small screw drive to overcome the lock
and then with a combination of deep well sockets and (maybe)a 4in. extension.
That baby was in hand, and installation was reverse of removal.....Tenn.Vol.
Old Oct 6, 2009 | 10:37 PM
snowisgr8's Avatar
snowisgr8
Default Same problem did head temp sensor repair?
I have the same problem going on with my bike right now. It revs up to about 13-1400 rpms when it is going to have the misfire and no power. Usually I rev it up a few times and it levels out. I know it is gone when the rpm's drop back to 900. Did the head temp sensor repair the problem? I checked the hoses in my tank and didn't find any issues. Thanks for the help!
Originally Posted by tmultra
I bought a 1998 ultra classic about a month and a half ago. It is fuel injected and has about 25,000 miles on it. Since I bought it it has run really good and I put about 2,000 miles on it so far. Today though it just isnt running right. When I get on the gas it really hesitates and seems like the engine is missing. Also I noticed that at idle my rpms went from about 800 rpm to about 1300 rpm. When I give it gas either stationary or to speed up, the engine just falls on its face. So far I pulled the spark plugs and they looked good and I also put some heet in the gas tank to eliminate the possibility of moisture in the gas. Any Ideas what the problem could be? Possible dirty fuel filter?
Old Oct 8, 2009 | 02:00 PM
tmultra's Avatar
tmultra
Head temp sensor fixed it for me. I ran about a thousand miles now since I changed it and its running good. Fairly easy fix. I had to lift the fuel tank about an inch or two so I could get in there to work. Cost me about $100 from the stealer.
Old Oct 8, 2009 | 06:45 PM
snowisgr8's Avatar
snowisgr8
Thanks for the response. This is the kind of thing that makes these forums work so well. I ordered mine online from Bikebandit.com for $43 I was told they have the best prices on genuine Harley parts.
Thanks again!
UrbanRunner
Feb 18, 2018 05:35 PM
PPBART
Jul 6, 2016 05:52 AM
bigtwin1228
Jul 24, 2013 09:04 PM
texasmail1962
Aug 30, 2011 01:08 PM
k-hook
Apr 30, 2011 07:19 PM
