Monster Oval Question?
Old Aug 30, 2009 | 07:12 PM
wjcbsr's Avatar
wjcbsr
Default Monster Oval Question?
I installed these with V&H True Duals in March and I love everything about them (except for one thing). When I installed them I painstakingly fiddled and farted to get them level from the back. Every time I go for a ride and come back they seem to be crooked. I've tightened the clamps up good and I can't seem to move them around by hand.
I'm getting real tired of adjusting them every time I go for a ride. Has anyone seen this or have any ideas on how I could fix it?
Thanks in advance,
Bill
Old Aug 30, 2009 | 07:15 PM
ks-waterbug's Avatar
ks-waterbug
My ovals have 2ea additional fasteners that hold them in place at the back... (beneath the side bags), but the clamp up front has also came lose on mine! Now, I check them out regularly..
Old Aug 30, 2009 | 07:19 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Are the two bolts towards the rear tight also? Are the pipes pushed onto the header pipes as far as they will go?
I have the same pipes and they do not move at all. Plus I used anti seize for easy removal if needed.
Don't be afraid to crank down on the front clamps. Use a 1/2" rachet or breaker bar to get good leverage. After a few heat cycles and re-tightening, they should not move.
Old Aug 30, 2009 | 07:22 PM
HDV-GLIDE's Avatar
HDV-GLIDE
If it's coming loose, it not tight enough.......You have to use more torque then the HD manual say to get a good seal and to tighten the clamp up to where it should be...
Old Aug 30, 2009 | 07:24 PM
ks-waterbug
I believe your correct, did this a couple back and no problems since! They dayum near fell off on a trip down to OK city...
Voony
Jun 12, 2011 10:58 AM
2011 FLHX
Jan 18, 2011 01:12 PM
cmvondran
Jul 28, 2009 10:28 AM
twilliams
Oct 7, 2007 12:52 AM
ESS9
Exhaust System Topics
Apr 13, 2006 07:59 PM
