Brake Squeak Gone
Old Sep 7, 2009 | 06:17 PM
rocknrod's Avatar
rocknrod
Default Brake Squeak Gone
I had a rear brake squeak. So I was looking for a rear floating rotor. Couldn’t find one so I removed the rear calliper cleaned it up, took out the pads cleaned the backs real well. Then I put some blue disc brake quite on the backs of the pads. Let em sit for 20 minutes or so and reinstalled everything. That was yesterday.
Today I rode around allot and the squeak is gone!
Piece of cake.
Old Sep 7, 2009 | 06:40 PM
dawg's Avatar
dawg
42551-08 $9.95 anti noise paste kit works too.
Old Sep 7, 2009 | 07:13 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Your choice
Go it every 2,500 miles when you service your bike if you are using sintered pads. This guide Brembo Brake Maintenance Guide PDF Download has always been available for your use.
Cleaning your calipers & pistons because of noise should be the last reason why you would perform brake maintenance. The reason why you may be hearing noise could be because the piston is being held out due to pad dust build up. I have been mentioning this for years on this forum. Read the frequency of warped rotors on this forum, what would you think could be the cause? Think about it.
Old Sep 8, 2009 | 06:19 AM
rocknrod's Avatar
rocknrod
I used that PDF thanks.
But I also used disc brake quite on the back of the pads.
Howler_LI
2014-2024 Touring Models
Sep 30, 2016 12:13 PM
MikeBel
May 4, 2013 05:08 PM
D2MOTO
D2MOTO
Aug 29, 2012 07:49 PM
DeathProof72
Jun 21, 2010 08:46 PM
SubZer0
May 19, 2006 11:56 PM
