Primary chain adjustment
Old Jun 14, 2006 | 06:46 PM
harris48cars's Avatar
harris48cars
Default Primary chain adjustment
Just checked the primary chain and it has a 1/4" play. The book calls for 5/8 " play. Is this too tight or does it matter as long as it isn't too lose?
Gary
Old Jun 14, 2006 | 07:04 PM
PhilM's Avatar
PhilM
Default RE: Primary chain adjustment
THere is usually a bit of runout on the sprockets that causes thight/loose conditions when measuring the chain play.
See if you can bump the starter w/o letting the engine start. Chances are that if you can do that, you will see that it's not that tight all the way around. Ideally, see if you can get your measurement at the loosest point.
Old Jun 14, 2006 | 09:25 PM
howieheels's Avatar
howieheels
what is the best way to adjust the chain. Mine was a little loose. I loosen the bolt two turns like the manual says and I have a hard time moving it up just a small amount. It seems to go to far and cause the chain to be tight. There has to be an easy trick here....
Old Jun 15, 2006 | 12:14 PM
huffhuff's Avatar
huffhuff
move the chain at least three time checking.
Old Jun 15, 2006 | 08:10 PM
motor1's Avatar
motor1
Take you scoot to a qualified Technician! If infact you are getting the reading you claim, you have problems! Sprockets do not have the out of roundness you claim to have.
Old Jun 15, 2006 | 10:35 PM
wnogood's Avatar
wnogood
The chain addjustment should be made at the tightest point in the chain. 5/8 is where I put mine, cold. Beleive it or not, too tight is worse than too loose. The tensioner shoe is a bit aggravating. It may take several tries to get it exactly right, but take your time and get it where it needs to be. Mine needed alot of adjustment at 1000 miles, but after 4000 miles ( the last time I checked it ) it was fine.
nogood o~`o
Old Jun 15, 2006 | 11:35 PM
howieheels's Avatar
howieheels
do you move it up and down with your finger or use a tool?
Old Jun 16, 2006 | 08:19 AM
wnogood's Avatar
wnogood
I used a 9/16 ( I think thats the size of the nut that holds the tensioner ) socket, and a 6" extension. When you get the nut loose enough to allow the shoe to move, just wiggle the socket while applying upward pressure and the shoe will move up. Like I said, it may take several tries to get it right where it needs to be.
nogood o~`o
Old Jun 16, 2006 | 02:18 PM
GTK's Avatar
GTK
Mark position of adjuster with slots and move up one slot at a time untill correct play reached
Old Jun 16, 2006 | 09:39 PM
Dsanchez's Avatar
Dsanchez
One thing to listen for...if it whines....its too tight.
