Rear Brake pads gone @ 5800 miles 2009 FLHX?
Old Sep 12, 2009 | 09:54 PM
RKKY's Avatar
RKKY
See it all the time at the shop. Bikes with no rear pads left and 90%+ on the front.
Old Sep 12, 2009 | 10:33 PM
jberg's Avatar
jberg
The Ride Like a Pro technique teaches you to ride the friction zone on the clutch and drag the rear brakes during low speed turns. Works real well on a big bike but at the expense of the rear brake pads. As long as you change them before it's too late you should be ok.
Old Sep 12, 2009 | 10:47 PM
shakak's Avatar
shakak
I just purchased an 08 SG with 4k miles on it when I took it in last week for a new inspection the rear brake pads were almost gone. I changed the pads myself they are easy to do
Old Sep 13, 2009 | 07:31 AM
KopperTop's Avatar
KopperTop
I ride a lot in rush-hour bumper to bumper traffic -- you know where you creep ahead a car length, then stop, creep, stop, etc. I use that RLAP technique for all that slow stuff and I do notice my rear white wall has much more dust on it than the front. On my Sporty, it was never a problem, with 900 lbs of Ultra, that low-speed stability requires more rear-brake. Sometimes after sitting in traffic for 30 or 40 minutes, I have to remind myself to switch to primarily front-braking once I get out on the open road.
Old Sep 13, 2009 | 08:37 AM
dog155's Avatar
dog155
Originally Posted by Ultraandroadking
If you are replacing your rear pads at 5,000 miles I'll bet you're not using your front brakes enough. Over 10,000 miles on my Ultra and still a ways to go, same with my RKC. Most of your braking should be done with the front brakes.
My first thought not using the fronts enough.The rears do wear quicker because our feet are much stronger,but 5000 miles? nope!
Old May 29, 2011 | 09:51 AM
Gator454's Avatar
Gator454
A persons riding style can have so much to do with how fast the brakes or the clutch wears out. If we think about it, the guy that does "dyno runs" from light to light and then "power braking" to stop, will cause a lot more wear than "grandpa" that never get up to the speed limit and then coast to a stop. Let's face it every one rides different.
Old May 29, 2011 | 10:00 AM
vistavette's Avatar
vistavette
Even if he is practicing this he has an issue with his bike. I spent a lot of time working on the RLAP stuff and I have 25k on my bike with the original pads; no issues yet. There has to be an issue with this bike. Even if he was all over the rear brake they should have lasted twice that long at a minimum. I guess its possible that he should look at his riding technique; I've hear of riders that use the rear brake almost exclusively and that would for sure cause that issue.
hardheaded
May 29, 2014 12:08 PM
glasspilot
Apr 21, 2012 06:47 AM
cewhit1
General Topics/Tech Tips
Feb 23, 2010 10:25 PM
myred55
Aug 17, 2009 04:46 AM
hfdarson1
Aug 12, 2008 10:32 PM
