Fuel Mileage
Old Sep 13, 2009 | 04:22 AM
RiverRatt000's Avatar
RiverRatt000
Stage III
Default Fuel Mileage
Hello all. Just signed up here. Hope I can get some help. I have a 07 Ultra Classic. Vance and Hines clasic slipons, Screaming Eagle breather kit and a power commander. I am only getting about 34 mpg regular riding and on a good day on the highway 40mpg. To me this is not right. Two dealerships have said nothing wrong there. Anybody having the same problems. Thanks for your help. Alan
Old Sep 13, 2009 | 08:47 AM
deadman77's Avatar
deadman77
Just about what I am getting with the PCIII, slip ons and a K&N AC.
Old Sep 13, 2009 | 08:50 AM
ranman469's Avatar
ranman469
welcome!
mpg depends on how you tunner is set up. if its rich to keep the bike running cool? your going to use more gas. you could have it dyno tuned. that way its set up for your bike.
i get 42-44
Old Sep 13, 2009 | 12:28 PM
EZ48's Avatar
EZ48
Your numbers are about the same of what I get as well. You might be able to improve it 1-2mpg by getting a dyno tune.
Old Sep 13, 2009 | 12:39 PM
will2002's Avatar
will2002
I only get 38-40mpg with a stock TC-88!
Old Sep 13, 2009 | 01:26 PM
frenchman's Avatar
frenchman
Lucky you. I get 30 MPG with the slip ons only. 2 up, highway, solo, backroads, doesn't matter Always 30 MPG. Looking into a SE breather right now. It's a 01 Standard.
Old Sep 13, 2009 | 01:34 PM
carguy's Avatar
carguy
I have a 2007 Street Glide. Stage 1 air, Stage 1 flash, Vance & Hines fishtails. I get between 45 & 50 mpg.
Old Sep 13, 2009 | 03:27 PM
EZ48's Avatar
EZ48
A lot of this depends on the riders style a well. I can probably get 45-50mpg if I go real easy on the throttle while cruising in 6th gear on flat highway. However I like to ride it like I stole it so my mpg suffers. My smiles per gallon is way off the chart however.
Old Sep 13, 2009 | 04:27 PM
jerseyjimk's Avatar
jerseyjimk
I to get more smiles then miles on a gallon of gas,to me thats priceless
Old Sep 13, 2009 | 04:32 PM
Sefferdog's Avatar
Sefferdog
I had basically the same setup. Pipes, hi-flow AC, and a Power Commander. Got around 35 MPG regularly. Tried leaning my map out and it didnt really make much of a difference.
Switched to a TTS Mastertune and had Doc down in Clermont, FL dial it in. Now I get around 45MPG. Bike runs like a champ!
