Roadking Whine
Old Sep 14, 2009 | 10:14 AM
sppxl0's Avatar
sppxl0
Default Roadking Whine
I have a 2002 RKC 31000 miles on it. Recently, I noticed that as I shift through the gears I hear a faint whine as each gear is changed. Sort of a increasing whine from going up as I wind it out. Does anyone else hear this on their RK? I recently changed from Bel Ray Gear Saver to Harley standard transmission for the transmission fluid.
Old Sep 14, 2009 | 02:06 PM
bigskyhd's Avatar
bigskyhd
I'd pull the cam cover and check to see if your spring loaded cam tensioners are going south. I heard the same thing on my bike and when I checked it out, I needed to replace the cam tensioners. a But they completely came apart, so I decided to go with the SE Hydraulic Tensioner Kit with the high volume oil pump. But you're much better off to check it early before things really come undone, cause then you're going to have a HUGE expense. Good luck.
Old Sep 14, 2009 | 05:18 PM
sppxl0's Avatar
sppxl0
I had them inspected last summer and the dealer said they were fine.
Old Sep 14, 2009 | 05:20 PM
UltraTheo's Avatar
UltraTheo
You say you just changed tranny fluid. I would first look there. Change it back out and try either Redline Heavy Shockproof or Amsoil Severe Gear 75-140.
WVICEMAN
EVO
Oct 4, 2016 11:28 AM
Smartbass
Aug 30, 2013 11:04 AM
Z
Exhaust System Topics
Dec 3, 2009 05:42 PM
Jim Kraft
Jul 25, 2009 11:00 AM
riden2low
EVO
Apr 13, 2007 02:23 AM
