2009 Street Glide PCV report
Old Sep 17, 2009 | 10:25 PM
Gary in Illinois's Avatar
Gary in Illinois
Stage III
Default 2009 Street Glide PCV report
On the chance that others are sitting on the fence considering Fuel Moto's Power Package, the following may be of some help. I have looked at the dyno sheets on Fuel Moto's web site but had a hard time relating this to real world performance (ie, a 20% increase in torque does not equal a 20% increase in performance). I purchased the Power Package and decided to install and test the parts one at a time. Some of the following are facts and some are subjective.
My interest was in seeing the effect on highway passing ability. I started in 5th gear at 2000 RPM (45 mph) and held the throttle open until 4000 RPM (90 mph) to eliminate any differences due to difference in shifting time or speed. I used the average of the time running in both directions the same day over the same level stretch of road to eliminate the effects of wind.
Times are as follows:
Bone stock = 15.3 seconds
Stock with addition of high flow air intake = 15.0 seconds (1.96% faster)
Stock with addition of high flow air & PCV = 14.4 seconds (5.88% faster)
I plan to run the same test when the new DT Jackpots are installed.
Fuel mileage ran from 42 to 44 mpg before the changes above. First tank after above changes yielded 42.8 mpg with similar mix of 1 up and 2 up riding over two lane highways, around town and back roads so there was virtually no change in fuel mileage in the same type of riding.
Subjective comments:
"Seems" to run somewhat cooler (but maybe because I want it to??)
Runs smoother with much less surging
Definitely pulls from stop easier and stronger, especially noticeable when riding 2 up
Hopefully this information will give those considering this package a real world feel for the changes they can expect. If there is any interest, I will add the results when I get the new Dyno Tuned Jackpot mufflers.
At this point I am very pleased with the changes. Very good bang for the buck.
Gary
Glyder
Aug 1, 2022 12:19 AM
RockerMike
Apr 18, 2012 12:33 PM
Intensefab
Apr 1, 2011 12:40 AM
rm4040
May 17, 2010 03:33 PM
09StreetGlider
Feb 17, 2009 10:58 PM
