Downshifting problem
Old Jun 18, 2006 | 11:46 PM
Cruiser22's Avatar
Cruiser22
2nd Gear
Default Downshifting problem
I am new to my 99 Ultra and had a quick question. I have noticed that when I am downshifting, unless I stomp on it fairly hard, I run the risk of the gears going essentially into neutral. This has no bearing on where I am in the chain. I could be going from 5th to 4th, 4th to 3rd, etc, and if I don't give it just enough boot it slips into neutral without going into neutral....if you can understand that. I have to hit it again to hit the gear I was looking for. Should I be worried about this?
Old Jun 18, 2006 | 11:59 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Downshifting problem
Sounds as though your shifter drum needs an adjustment...
Quite a PITA, but doable....
Get a svc manual, you will need it.....
86glider
Aug 31, 2018 01:38 PM
RidemyEVO
EVO
18
Apr 16, 2015 08:17 AM
BiggestDawg
Nov 2, 2010 07:11 PM
harley_badboy
May 18, 2010 07:07 AM
Clarkit
Apr 21, 2008 10:12 AM
