Help change the gas tank on my 09 EGS
Old Sep 20, 2009 | 06:16 PM
mrthinkshesfunny's Avatar
mrthinkshesfunny
Default Help change the gas tank on my 09 EGS
I want/need to change my gas tank on my 09 EGS after a little Evel Kneviel act that I pulled a couple weeks ago.I usually do all my own work.After reading in the service manual it doesn't sound complicated.I know I need to buy the cam plate wrench to open the top of the tank.Anyone done this that has any pointers or ideas I'd sure appreciate the help.Actually any thoughts would be appreciated.
I found an 08 SG tank that I would like to put on to replace my tank.Does anyone know if this tank will fit right? I wonder if there are cosmetic issues like a big gap between the seat and tank or is the tank a direct fit swap.Thanks
Last edited by mrthinkshesfunny; Sep 20, 2009 at 10:53 PM. Reason: stated year of possible replacement tank
Old Sep 20, 2009 | 11:19 PM
leon anthony's Avatar
leon anthony
08 tank should be the same as 09 both are 6 gallon tanks 07 and early are 5 gallon and will not work for your 09
Old Sep 20, 2009 | 11:59 PM
dawg's Avatar
dawg
Don't waste your money on the wrench. There are tabs on the cam lock, take a blunt piece of flat bar or something and gently tap each tab using the piece of whatever and hitting it with a rubber mallet. As you work your way around the tabs on the cam lock you will see it moving and "unlocking." Here's a pic of the tabs on the lock
Old Sep 21, 2009 | 05:10 PM
mrthinkshesfunny
Thanks Dawg,I need to save all the coins I can for the parts.
LetItRide
Sep 13, 2011 12:09 PM
extsieg
Jan 9, 2011 01:42 PM
skipper469
Feb 6, 2010 09:59 AM
CHGO5OH
Aug 20, 2009 02:02 PM
Raven Rider
Nov 20, 2008 09:50 PM
