Need help with road glide windshield install
Old Sep 21, 2009 | 12:17 AM
clayman's Avatar
clayman
Default Need help with road glide windshield install
Hello...
I am having a hell of a time installing the windshields on my road glide. My problem is with the well nuts, they seem to always pop out. I just installed the harley 3 inch over shield and think its great but the well nuts wont stay in. Either this is a really stupid design or im doing something wrong. It seems worse with the taller windshield, ive have no problems with my short ones. Any help or advice would be greatly appretiated.
Old Sep 21, 2009 | 07:14 AM
wonbyone's Avatar
wonbyone
in changing out several windshields, I found the oem well nuts to be lacking. So I got some longer ones at Ace hardware, they work like a charm, much easier to install also. --Bill
Old Sep 21, 2009 | 07:25 AM
1flhtk4me's Avatar
1flhtk4me
Try this......As soon as the screws engages in the nut,push on the screw while turning.This will expand the length and tighten up better.
Old Sep 21, 2009 | 07:40 AM
Tyroneshoelaces's Avatar
Tyroneshoelaces
when installing the shield you must push the shield against the well nut when tightening, if not they will pop out and you will risk the shield scratching the fairing.
Old Sep 21, 2009 | 07:46 AM
bullseye's Avatar
bullseye
I have "lost" several inside the fairing, now that is not fun. I always keep some extra ones around just for that reason. I think it is a very poor design myself. Didn't think about ACE, I may try theirs. Also, I've seen somewhere on this forum a link to an aftermarket brand that claims to be better. If anyone knows who that might be I'd appreciate a PM. I searched and could not find it.
Old Sep 21, 2009 | 08:22 AM
EasternSP's Avatar
EasternSP
I've used toogle bolts when in a pinch. The rubber that holds the well nut doesn't hold up well to repeated threading of the screw.
Old Sep 21, 2009 | 10:20 PM
clayman's Avatar
clayman
Default Thanks
for the replys. Ive been buying them from home depot, they seem to have been working on the lower shields but on this tall shield they keep popping out. How tight should i be going with them. Has anybody with tall shields had problems with them staying in.
Thanks
Old Sep 21, 2009 | 11:30 PM
Minglewood's Avatar
Minglewood
The well nuts included with Clearview's shields work much better. Perhaps John would send you a few, in the hope that you might buy one of his shields sometime down the road. Clearview is a HDF sponsor.
Old Sep 22, 2009 | 12:13 AM
clayman's Avatar
clayman
Default minglewood
Thanks for the info, will give it a try.
Old Sep 22, 2009 | 08:47 PM
ncbeast's Avatar
ncbeast
Get new ones at Lowe's.
