Installing Kuryakyn Cruise boards question
Old Jun 24, 2006 | 11:35 AM
Garrison1383's Avatar
Garrison1383
Default Installing Kuryakyn Cruise boards question
Instead of buying highway pegs... i picked up a set of Kuryakyn cruise boards to mount on the front crash bars.....
For some reason the clamp that was supplied doesnt fit around the crash bar that well and i cant get the holes to line up in order to push the allen bolt through and tighten them down.
Is there a trick here that i'm not seeing? I just gave up because i didnt want to scratch up my crashbars trying to get these on.
When i ordered they didnt ask me what size crash bars i have -- they are stock so i didnt think i would have a prob.
HELP !!!!!!
garrison
Old Jun 24, 2006 | 11:48 AM
dchoran's Avatar
dchoran
Default RE: Installing Kuryakyn Cruise boards question
That's funny - I had problems with mine also on an 05 Ultra. Had to really fight to get them on. Couple things.
1.) Fit the crash bars "OK" after a battle, but the shaft with the O ring clip holding the footshoe on doesn't go all the way through and it can't be clipped at the end??? It is too short - defect in design???
2.) After a couple hundred miles on these footboards, my engine started making a strange noise at 30 mph+. Almost brought it to the stealership. By accident I determined it was the cruise boards rattling. They don't seat tight enough in the down position and will rattle like crazy - sounds like a wobbly piston - I put some rubber compound on the seat to knock off the rattle.
Other than that, they're AWESOME!!!! Get a lot of looks from folks!!! And man are they COMFY!!!!
Old Jun 24, 2006 | 12:19 PM
bountyhunter's Avatar
bountyhunter
The clamps are a tight fit but with a little patience you will get the bolt started. You need a VERY small pair of snap ring pliers to get that tiny clip on the shaft. Yep, awesome and comfy!
Old Jun 24, 2006 | 07:00 PM
Garrison1383
Thanks fellas!
Old Jun 25, 2006 | 02:15 PM
Garrison1383
Dchoran - thanks for the photos, i was thinking about buying fairing lowers when the weather gets cooler and wasnt sure if the cruise boards would work w/ the fairings ..... looks like its tight -- but you got it
chasen12
Jun 13, 2009 09:44 PM
BadBoyFLSTC
Jun 3, 2008 01:20 PM
ronyd
May 7, 2008 05:42 PM
bowhnter7
Feb 14, 2008 01:26 PM
baltimorebook
Sep 6, 2007 05:14 PM
