How to use a jack
Old Jun 27, 2006 | 11:15 AM
Manish_Hawg's Avatar
Manish_Hawg
Default How to use a jack
Yesterday I asked what jack to buy (Pep Boys/Sears) but I should have asked how to use it. I assembled my jack and practiced going up and down before jacking up the bike. I jacked up the bike and every thing was great. But when I let the bike down it fell over on the crash bars (Thank God for Crash Bars). I did have the kickstand down but it fell to the right. I talked to my buddy and he said he always puts the jack on the same side as the kickstand, looking at some pictures I see some put the jack on the right side. Is there a correct side. I did lift and lower the bike 3 times successfully but another time it would have tipped over again if I wasn't prepared.
Please send me pointers on how to lift and lower the bike correctly.
Old Jun 27, 2006 | 11:52 AM
sleepneagle's Avatar
sleepneagle
Default RE: How to use a jack
I don't know what you were lifting. I raise my classic and roll it around and have never dropped the bike. I always raise from the right side and leave the jiffy down and in place. When lowering I hava a hand on the bike and ease it over on the jiffy to make sure it is stable before letting go. Otherwise you better start using the securing straps.
When using the right side: place the left jack pad under the flat bar near the trans and the right bar is then under the engine. besure that there is 1 to 1.5 inches of lift pad showing outside the frame on bothsides of the bike.
Old Jun 27, 2006 | 12:05 PM
Basz's Avatar
Basz
ORIGINAL: sleepneagle
Like SnoozingEagle Said - I always keep a hand on the bike when lowering and lean it slowly to the stand.
Old Jun 27, 2006 | 12:28 PM
Manish_Hawg
I am lifting an 05 Road King Classic.
Should I straighten the bike upright when lifting or can it still be leaned over on the stand?
Old Jun 27, 2006 | 12:36 PM
bountyhunter's Avatar
bountyhunter
I put the jack in from the low side (left) and pump it up from the jiffy stand.
Old Jun 27, 2006 | 12:38 PM
sleepneagle
I have to slip mine in from the high side part way and then bring the bike up to center before pumping the jack.
Old Jun 27, 2006 | 12:45 PM
StreetDreams's Avatar
StreetDreams
6th Gear
My SG stays on the stand/jack so I can roll it out of the way. Never droped it and I always leave the jiffy down just so I wont forget it....
Old Jun 27, 2006 | 01:34 PM
GTK's Avatar
GTK
Always raise my 05 RK from the rt side and when lowering slowly,I hang on to the rt handlebar grip to ease the bike back onto the jiffy stand.
Old Jun 27, 2006 | 01:43 PM
Bigfoot's Avatar
Bigfoot
I Jack mine from the left side and just ease it off the ground and back down with the Jiffy Stand down. Make sure you let it down real slow. Also, when it is on correctly, the bike os fairly well balanced.
Old Jun 28, 2006 | 02:46 AM
websterdan's Avatar
websterdan
I always go from the right side, nothing is in my way when I check clutch, primary chain or take the filter off. ALWAYS keep a hand on bike when raising AND lowering.
