Starter Issue
Old Oct 10, 2009 | 05:34 PM
zzmellio's Avatar
zzmellio
Default Starter Issue
Okay. My problem is 2007 RKC
Bike cold it starts fine. Once the bike starts to warm up, and you try to start it. I get a metal on metal/grinding/ stripped gear sound. I pulled the primarry cover and inspected the ring gear no damage. I am now look at the problem is either the starter clutch or the starter pinion gear or the whole starter. Battery is good and checked all cables for corrosion. Checked starter torque specs/all is good.
Any advise is welcome.
ZZ
Old Oct 10, 2009 | 05:45 PM
dawg's Avatar
dawg
So you checked the fasteners torque per the service bulletin on issues with 07 starters? If you did and was fine, I would say it's probably the starter clutch.
Old Oct 10, 2009 | 05:48 PM
zzmellio's Avatar
zzmellio
I did check the torque. Book says 25 to 27 ft.lbs. I have the clutch off now and I cant see any signs obvious damge so to say. I know metal takes on a diffrent shape when heat is applied. Dawg do you have ay tell tale signs to look for in the starter clutch>
Old Oct 10, 2009 | 09:11 PM
dawg's Avatar
dawg
Read THIS if you haven't already
Old Oct 10, 2009 | 09:17 PM
Indianspringsaz's Avatar
Indianspringsaz
Thanks, Something I need to check.
Old Oct 12, 2009 | 08:11 AM
ultraherbie's Avatar
ultraherbie
Default starter clutch
Dawg I have mine in this weekend having the starter clutch replaced. Has your Annv. had the same problem?
Cazimere
Feb 11, 2015 12:06 AM
hyp05fxdl
Mar 8, 2009 09:14 PM
lowglide88
May 11, 2008 09:12 AM
Jameson
Sep 4, 2007 11:32 AM
byrdi
May 9, 2006 02:07 AM
