View Poll Results: Have you had any issues with SE255 cams in a 96" motor???
yes
4.55%
no
21
95.45%
Voters: 22. You may not vote on this poll
guys with 96" with SE255s
Old Oct 21, 2009 | 06:10 PM
bmaier's Avatar
bmaier
yes, thanks for the responses everyone. Brettnbama, what kind of pipes are you running there?
Old Oct 21, 2009 | 06:45 PM
brettnbama's Avatar
brettnbama
Vance and Hines Big Radius 2 into 2's
Old Oct 21, 2009 | 07:12 PM
Taterdigger's Avatar
Taterdigger
Thumbs up
No problems here but I'm only a couple weeks into the change. A little more mechanical noise and a different exhaust note. As far as gas mileage goes... who knows, its been all over the map since I bought the bike new.
Old Oct 21, 2009 | 07:26 PM
SE120RG's Avatar
SE120RG
No problems here with the cam install. I did have to install the SE high performance clutch spring to keep the clutch from slipping and I have increased valve train noise that sometime bugs me.
Old Oct 21, 2009 | 07:37 PM
Taterdigger
Whitedogg, I've always thought the clutch was sort of 'buttery' on my SG. Is the clutch lever pull still tolerable with the new spring?
Old Oct 21, 2009 | 07:46 PM
SE120RG's Avatar
SE120RG
Very tolerable. It is stiffer than stock but not horrible. After I installed the cams, I could jump on the throttle at any speed and any gear and the clutch would break loose - rpm's would jump way up. I switched from amsoil in the primary and changed out the clutch spring and problem was solved.
Old Oct 22, 2009 | 11:11 AM
iclick's Avatar
iclick
Several months ago someone mentioned objectionably high top-end noise and mentioned he had used non-tapered adjustable pushrods on his build. At that time he said he would be trying the tapered adjustables in search of a way to quieten-down the noise. Was that you and if so did you make that change?
I can barely hear any valve-train noise on my bike with my helmet on, only slightly if any more noticeable than stock, but when I remove the helmet I can hear the top-end more readily. I can't say how much it compares to stock since I don't think I ever rode the bike without a helmet in stock form. Several friends who own stock-cammed bikes have listened to mine at idle and said that it is a bit "clickier" but not much. I expected some increased top-end noise because of the higher lift on the lobes but didn't get it, at least not to the extent that I anticipated.
The exhaust tone is different, too, not the "potato-potato" I had hoped for--and as I mentioned earlier the exhaust volume is higher. It's enough higher to prompt me to order one step smaller baffles for the Jackpots (2" down to 1.75"), which I did. That helped and didn't alter the performance any that I could tell.
Regarding the clutch slippage, you're the first I've heard who's had this problem. The stock clutches theoretically can handle ~110 ft/lbs of torque, which is at least 10% above that which you will encounter with TC96 and no other mods.
Old Oct 22, 2009 | 03:12 PM
HarleyWood's Avatar
HarleyWood
I voted yes...
I've rec'd a speeding ticket for 20 over (85) and a warning for 10 over...
Old Oct 22, 2009 | 05:40 PM
mastery's Avatar
mastery
Originally Posted by HarleyWood
I voted yes...
That's not a problem with the cam. That's a problem with your overly strong wrist muscles.
Old Oct 22, 2009 | 06:51 PM
SG 1's Avatar
SG 1
Man I gota stop reading these cam change threads. You people are gonna cost me money.
