LED Lights
Old Oct 22, 2009 | 10:42 PM
hartk1's Avatar
hartk1
Default LED Lights
Do I need an equalizer module if I'm adding LED lights and if so, what is it suppose to do?
Old Oct 22, 2009 | 10:46 PM
BadPiggy's Avatar
BadPiggy
LED's in what?
Brake? No
Turn Signals? Yes
LED's use minimal voltage and won't operate properly without something to make the module think it's using the standard amount of juice required.
The load equalizer steps in and makes the system think it's pulling more current than it actually is.
Old Oct 23, 2009 | 01:28 AM
lowleveldriver's Avatar
lowleveldriver
Originally Posted by BadPiggy
LED's in what?
Brake? No
Turn Signals? Yes
I agree
Old Oct 23, 2009 | 05:26 AM
Garemlin's Avatar
Garemlin
As Badpiggy said no on brake and yes on turns (and any others). Do yourself a favor and pick up a Biketronics Smart Equalizer. One is all you need for the whole bike no matter how many LED's you add. Alarm compatible. Completely plug n play OEM connections with very little heat and a no hassle lifetime warranty. You can pick one up for a lower that direct price through any discounted Drag Specialties distributor.
Old Oct 23, 2009 | 05:38 AM
StreetGlideMedic's Avatar
StreetGlideMedic
Badlands is right. Where are you trying to put your LEDs? Now...if you have a brake light and want to go LED you're safe without a load equalizer normally. If you want to install rear or front turn signals and go LED this is where it get a wee bit different. Usually if you only go with one set of LED turn signals it's not an issue and your blinker will stay good. BUT, if you go with BOTH front and rear LED turn signals you need to get a load equalizer.
Badlands makes the Illuminator III Load Equalizer and it works fantastic. No heat coming from it, has an excellent reliability rating. I've used mine for awhile. Installed on others bike and have had zero issues with this module.
Here's the link if you'd like to look it up:
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm.
Good Luck and Ride Safe, Mike
Old Oct 23, 2009 | 06:32 AM
FLHTCU Owner's Avatar
FLHTCU Owner
If you have the security system, make sure you get the load equalizer that is compatible (i.e. won't adversely impact the security system).
Old Oct 23, 2009 | 07:14 AM
maineultraclassic's Avatar
maineultraclassic
The Badlands module is the only way to go, it's completely plug-n-play, works with security systems, and doesn't heat up at all.
I changed all the lights on my bike to LEDs, only standard bulbs left are the headlight and passing lamps.
Steve
Old Oct 23, 2009 | 07:44 AM
baldeagle503's Avatar
baldeagle503
Steve
+1. Plug and play takes all the brain work out of it, and it has worked flawlessly for me.
Old Oct 23, 2009 | 09:20 AM
hartk1's Avatar
hartk1
Actually they are on a trailer I bought. Tail/Turns, brake, and side marker.
Old Oct 23, 2009 | 10:10 AM
TheShrink's Avatar
TheShrink
Just plug it in then. Your machine won't even know it's there. You don't need to do anything. If you change the signals on the bike though, get the Badlands.
