Front Wheel Bearings leaking???
Old Oct 23, 2009 | 09:47 PM
09BlueRoadKing's Avatar
09BlueRoadKing
Default Front Wheel Bearings leaking???
I have 4300 miles on my bike and the other day while cleaning her up noticed what looked like some kind of black looking stuff (kind of greasy feeling) around the right side of the front wheel bearing. Are the bearings sealed or could they leak?? Will be taking the bike in at 5000 for service will inquire about it then, was just wondering if anyone has any clue what it might be.
Old Oct 24, 2009 | 12:25 AM
BadPiggy's Avatar
BadPiggy
Bearings are sealed.
Most likely it's anti-seize seeping from between the bearing and wheel.
I wouldn't sweat it.
Old Oct 24, 2009 | 07:00 AM
1flhtk4me's Avatar
1flhtk4me
It is possible for the seals to leak.
Old Oct 24, 2009 | 07:06 AM
n8dc's Avatar
n8dc
Ive seen a couple posts about this and yes the grease was leaking out of the bearings and eventually they failed. Now in no way am I suggesting thats what is happening with yours but if you havent yet is clean that area and keep a close eye on it.
Old Oct 24, 2009 | 07:08 AM
Notgrownup's Avatar
Notgrownup
They are just happy...
Old Oct 24, 2009 | 07:28 AM
Estil's Avatar
Estil
My front bearing went out at 15K miles. Service tech found when changing front tire and was covered by warranty. If you're taking in for service soon, I would have it checked.
Old Oct 24, 2009 | 08:07 AM
lp's Avatar
lp
Your really going to need to inspect it a little closer. Check the sides of the bearings and ensure the black seals are not cracked. Is the material coming out between the bearing and spacer? Probably antiseize in that case.
Rub the material between your fingers... does it turn silverish/gray. If so thats antiseize...
lp
Old Oct 24, 2009 | 09:12 AM
autochek's Avatar
autochek
I had my front bearing done at 4800 miles and now at 5200 my bike is in the shop getting the rear done. Yes, people are having issues with them. Listen for a whine or roaring noise when leaning into a turn. If you hear anything, get it in right away.
My dealer also replaced the front tire at the same time. I am waiting to find out if the rear tire will be covered since it is severely cupped also.
BTW, do not use a power washer around the rims. The bearings are sealed, but the pressure will get water in there. This will lead to premature failure.
Old Oct 25, 2009 | 04:58 AM
jd533's Avatar
jd533
Dealer replaced my front bearings under warranty at 4,000 miles.
Old Oct 25, 2009 | 05:04 AM
jpooch00's Avatar
jpooch00
I've seen several threads on other sites and one on this one about wheel bearing failures on these bikes. I'd get it checked.
