adjusting pushrods
Old Oct 26, 2009 | 12:13 PM
olelucky's Avatar
olelucky
Default adjusting pushrods
i put a set of new lifters and SE adjustable pushrods in a 2000 heritage yesterday. and can't get them to bleed down. we soaked the lifters in oil prior to install. put them in as per HD instructions. we waited 20 minutes for bleed down. no compression. waited on hour. no compression. anything past 1/2 turn and waiting... no compression. re-adjusted to the 2 1/2 turns and left it overnight. this morning... still not bled down. what am i missing here?
Old Oct 26, 2009 | 12:17 PM
widowmaker221's Avatar
widowmaker221
Did you adjust each pushrod on the heel of the cam?
Old Oct 26, 2009 | 12:50 PM
olelucky's Avatar
olelucky
yes, i've done these several times. did mine last week. just can't figure this one out.
Old Oct 26, 2009 | 01:40 PM
widowmaker221
Sounds like you will need to pull em out. I could understand one collapsed lifter but not all 4 at once. Who knows could have been a manufacturing defect, wrong type of lifter etc?
Old Oct 26, 2009 | 01:46 PM
texas_speed_freak's Avatar
texas_speed_freak
what kind of lifters did you use? semi-solid lifters have different pushrod adjustment procedures. Even if you put the limiter blocks in the stock style lifters you have a different adjustment procedure
Old Oct 27, 2009 | 09:40 AM
mainshaft's Avatar
mainshaft
It does sound kind of odd that they are all acting the same way, let us know what you find out. good luck.
Nickd2689
May 17, 2018 01:43 PM
stro1965
Apr 1, 2013 08:18 PM
cowentz
Mar 9, 2012 08:53 AM
jackinthebox
Exhaust System Topics
13
Nov 15, 2010 10:08 PM
2003 Heritage
Aug 23, 2009 04:30 PM
