Front wobble fixed. Very easy fix.
Old Oct 27, 2009 | 05:11 PM
psychocircus's Avatar
psychocircus
ditto what skratch says...
Old Oct 27, 2009 | 05:41 PM
wldbill's Avatar
wldbill
+1 bearing adjust needed.
Old Oct 27, 2009 | 05:58 PM
Whackone's Avatar
Whackone
There is a section on adjusting the head bearings in the service manual. I don't remember it verbatium but you put it up on a lift and move the fork to the right, let go and see where it stops. That will determine what action is needed. Read the manual.
Old Oct 27, 2009 | 06:07 PM
SG 1's Avatar
SG 1
Very strange that 5 pumps of grease would stop a low speed wobble. Me thinks temporary fix at best.
Old Oct 27, 2009 | 09:05 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
that grease just filled up some slop in the head bearing .
Old Oct 27, 2009 | 09:43 PM
oinker02's Avatar
oinker02
Friend, there ain't no way grease can truely fix your problem. I'm glad you have a temporary respite, but keep looking as you might have a problem that will put you down hard.
At best, the grease is covering up a flakey bearing or too loose bearings. As the grease thins and flows down out of the bearings, the problem will resurface.
My first advice to you is to conduct a Fall Away test as described in the service man. It is best done with hand controls and cables removed from bars. They are simple to slip off if your bars are not internally wired-just loosen the screws and slide them off and let them hang as you do the test.
98hotrodfatboy
EVO
14
Sep 3, 2021 01:30 PM
kel03
Feb 25, 2018 08:36 AM
MikerR1
Oct 18, 2016 11:13 AM
Skippy97
Jul 30, 2013 11:06 PM
CobraEd
Mar 10, 2011 05:48 PM
