break fluid
Old Oct 28, 2009 | 01:26 PM
The Nev's Avatar
The Nev
Default break fluid
I did a search and couldn't find anything on this subject. So has anyone changed out their break fluid and if so how did you do it? Was it a difficult job, seems it would be easy but I've learned the hard way that some of the "easy" jobs were the most difficult.
Old Oct 28, 2009 | 01:30 PM
old.gezr's Avatar
old.gezr
Brake fluid is spelled BRAKE fluid. Try a search with that.
Old Oct 28, 2009 | 01:39 PM
Jinks's Avatar
Jinks
Open the reservoir, pump gently while opening a bleed valve. Use a clear plastic tube to route BRAKE fluid to a container. Keep enough fluid in the reservoir so that you don't pump air into the line. When the fluid at the bleed valve becomes clear you've changed the BRAKE fluid. Top off the reservoir & you're done.
Old Oct 28, 2009 | 01:42 PM
bluffalobob's Avatar
bluffalobob
I try to stick to either water or Gatorade when I need a break, it's the best way to hydrate.
Not sure how you're built, but I have a valve about halfway down my body that is used to drain fluids, among other things. I have to stand a little closer and stand a little longer than I did when I was a young lad, but it still works ok.
Barrenmug's Avatar
Barrenmug
Here's a thread on it. Probably others as well.
Old Oct 28, 2009 | 02:07 PM
CroK's Avatar
CroK
Harbor Freight and auto parts stores sell a break bleeder. It's a hand pump of sorts that you attach to the bleeder valve on the calipers. There is either a container attached or a hose that feeds the fluid into a remot container depending on which one you get. It will allow you to pull the brake fluid down and at same time replace with new fluid. This helps keep air from being trapped in the system which would require further bleeding of the system to remove the air pockets.
It can be messy so keep lots of shop rags or something to wipe spills up if hoses become disconnected.
This is a link to a few that HB sells. Again, you don't have to use these, I just put them here so you can see what I'm talkin about...
http://search.harborfreight.com/cpis...=brake+bleeder
Old Oct 28, 2009 | 02:39 PM
rochkes's Avatar
rochkes
My break fluid is any brand of cold beer. It changes itself shortly after each break. I never change my brake fluid.
Dennis
Old Oct 28, 2009 | 02:42 PM
The Nev's Avatar
The Nev
Talking dain bamage
Ok Ok already brian brane brayne bra... oh forget it I had a fart!! I'm a union worker what do you expect.
Thanks for the help with the brake job and the spelling
brettnbama's Avatar
brettnbama
just make sure you use HD brake fluid or it will void your warranty
Old Oct 28, 2009 | 03:38 PM
tx-skydiver's Avatar
tx-skydiver
I would expect that typing isn't your job and a workorder has been placed to have the typist come type it. Since he spelled Brake incorrectly, you can file a grievance.
I change mine in the bike by using a syringe to suck out reservoir, then reverse bleeding. It doesn't get the stuff still in the lines, but its alot of it and I feel pretty good about it.
zworld
Jan 28, 2012 11:56 AM
jnogreen
Nov 20, 2010 12:00 PM
albngore
Feb 20, 2009 10:50 AM
hdpearson13
Apr 19, 2008 04:08 PM
madfish
Oil Archive (no new posts)
Feb 16, 2005 03:58 PM
